select partitons to wipeYou should have never done that. That backup is there so when you do something to your device and it screws it up then you have the ability to fix your device by restoring it with your backup. Wiping your backup literally makes no sense lol.
Anyways, I cannot provide you with an RUU because you are S-On and on Jelly Bean. The RUU is for ICS which requires you to downgrade the HBoot which can only be done if you are S-Off. As of now, this is really the only thing I could find available for the K2_UL. Its a Rom. Place it on to the root of your external sdcard.
K2_ul (LTE): k2ul_JB_2.14.401.6_stock_odexed_03_06_13.zip - Mirror
Md5 Sum: 5C3BDDBAD1690794925284AA2E11150B
How to install:
First of all:
Download the zip file.
Wipe/format data/system/cache/dalvik cache, factory reset.
Flash the zip through custom recovery.
Htcdev.com unlocked users who are not S-Off have to extract the boot.img from the zip file and flash it afterwards over fastboot via PC with the command:
Code:fastboot flash boot boot.img
Then reboot your device.
dalvik cache cache data int_sd android secure sdcard saystem; where do i find factory recovery to wipe
