I just switched from winmo 6.5 for years to Android. I love it so far but i really miss one thing from winmo..... I want to snooze things diff times. Like snooze something for a hour or a day......and choose that each time. I could do that easy in winmo and said Android dont do it by default. Other wise im loving my new Rooted EVO.
How do I stop the vibr on the dialer
Heh, you're in the wrong forum.![]()
Ok sorry i need to read more..... lol I just need general android tips and tricks not incredible.... sorry
when using the video camera the led's will not turn on i do alot of videos in the dark how do i fix this
Well, I have a few techniques that will help generate close to 10mph if you work on it every other day or so.
1.) Work your stomach. The trunk rotation in pitching supplies an incredible amount of speed to your pitch. If you do sit-ups every day you will see a velocity increase. I guarantee it.
2.) As previously mentioned, legs. Strong legs allows you to explode down the mound and put some insane heat on a pitch.
3.) Stay away from bicept lifting and military pree (overhead bench) Believe it or not, the muscles used for that lifting actually slows down the pitching motion. Work your chest, the back of your shoulder and tricept.
4.) Long Toss. The easiest way to make your arm stronger is to do long toss daily or every other day. Work back to 180feet, and then maybe 200 if 180 becomes easy.
5.) Clean your mechanics. Its important to be comfortable, however a few tweaks, such as a better stride, or an improvement in balance during your leg lift can add a few mph.
If you do all of these and work on them hard enough, you will see a great increase in your pitching. I can't guarantee 10mph, but there will be an increase. Just be smart, don't lift too much weight to prevent injury, and have fun.
Good Luck!
Use the trackball.How do I move the text cursor? I know tapping on the word space will put the cursor there, but how do I fine tune it to a particular letter?
If google sky doesn't seem to work properly move the phone in a figure 8 pattern.
As if it was your match box car and you were driving it in a figure 8 pattern.
My kids call it my phone dance.
But it recalibrates the compass.
Also if you have a case for your phone with a magnet in it, don't have it near by when using google sky, the magnets will throw off the compass.
This is pretty simple but took me a few weeks to find.
Use your volume rocker to adjust the volume of your ringer. Go all the way down to go to vibrate. I find this to be the quickest way to put my phone in or out of vibrate mode.
Does that make sense?
What's the fastest way to put my phone on silent (not on vibrate)?
Fastest would be a widget on your home screen, that would be one button to press...you can find them in the android market.
There are also apps that allow you to turn the phone over to turn off the ringer. Turn Silent is one. Silent Time also lets you silent you phone based on the time of day so that would be really fast =)
Good Luck!
