Talderon
Android Expert
This information is now old. Please use this as a troubleshooting guide, but not be used as a FLASHING GUIDE.
More complete guide for other ROM's is here:
http://androidforums.com/htc-leo-hd2/273125-guide-android-your-hd2-start-finish.html
My original guide posted HERE
Ok, once and for all. I have the NAND build working, perfectly, no issues and I have followed these steps multiple times to make sure it works and has worked for me on EVERY flash. If you can't follow numbered instructions, you're going to mess it up.
I am assuming you already know how to Flash NAND builds, have MAGLDR 1.11 installed and all ready to go, if not, start with other detailed and wonderful tutorials that others have written, then come back here.
Best guide out there is Flashing Your First HD2 NAND Android Rom [For Newbs] - xda-developers
1. Download the NAND build of the ROM HERE
2. Extract it onto you Hard Drive somewhere you can get back to it (use 7zip)
3. Download ClockworkMod Recovery from HERE
4. Extract ClockworkMod zip onto your Hard Drive
5. Copy the files in the copy_to_sd_root folder onto the ROOT of your SD Card
6. Download GAPPS for GingerBread from HERE (this is the "26" version, do not use the "28" version as there are issues with it at this time)
7. Copy the GAPPS zip file onto the ROOT of your SD Card
8. Turn OFF your phone
9. Power it on and keep holding the power button (this is the RED button that you used to turn it on). Do NOT let go until you are in the MAGLDR MENU screen
10. Connect the USB Cable at this time if it is not already connected
11. Using the volume down, goto Option 4: USB Flasher and press the 'Call' button
12. RIGHT Click on the Installer in the ROM Folder you extracted in step 2 and click "Run as Administrator"
13. Follow the on-screen prompts and flash the ROM
14. Once it is done flashing, boot the phone fully into the ROM
15. Once booted, reboot the phone allowing the ROM to fully load again
16. Once it is fully booted, power OFF the phone
17. Power it on and keep holding the power button (this is the RED button that you used to turn it on). Do NOT let go until you are in the MAGLDR MENU screen
18. Select "Boot AD SD" and press the 'Call' button and recovery will load. THERE WILL BE ERRORS, BUT IGNORE THEM
19. Using the Volume buttons, navigate to "install zip from sdcard" and press the 'Call' button
20. Using the Volume buttons, navigate to "choose zip from sdcard" and press the 'Call' button
21. Using the Volume buttons, navigate to "the GAPPS zip file you downloaded in step 6" and press the 'Call' button
22. Using the Volume buttons, navigate to "Yes - Install {zip filename here}" and press the 'Call' button
23. Once this is completed, navigate back to the main menu by pressing the power button (this is the RED button) to get back to the main menu.
24. Select reboot system now and press the 'Call' button
Oh, if you pressed the red button too many times and are now at a blank screen, just pull the battery and power up.
Once you do all of this, then you are all set. Mine works like a charm. Wifi, GPS, Data, camera, camcorder, Calls work, Angry Birds work, Facebook, the whole ball of wax!! Sorry to the twitter folks, I don't use Twitter, however, the app does download from market but will not install, something about a missing shared library.
If you get FC's on games, move them from SD to Phone storage and should work fine (Angry Birds for example).
Hope this helps others out.
