Hey JBnex, I moved this to the Intl All Things Root section. Thanks for understanding.![]()
Um, I have Franco kernel updater app, any tutorial on how to flash it and use the settings? It looks kinda dangerous....
And which build should I use? I'm on 4.1.1 jelly bean stock
Is the nightly safe? And what is dalvik cache? Does this wipe my device?
I can only flash kernels that suit my device and firmware right? I have Jelly Bean so this is right for me?Clearing Dalvik cache won't wipe any data from your phone, so you are safe. It is like the Windows virtual memory cache and helps your device apps being executed from cache. Just helps make everything ran efficiently. You'll find the dalvik cache wipe under wipe or advanced in the custom recovery.
Should I use a custom recovery or the in all auto flash?Don't worry about backing up your kernel. No need. Also no need to wipe anything beforehand.
Choose the 384 version (clock speed of GPU) for stability. If you like the kernel then try the 512 version - come phones won't run it - not all GNex's are created equal!
For Franco JB kernels just pick the latest. There is no milestone version yet.
Hmm, I'm at min 384 with Franco Kernel for JB, I can't go lower than that, how do I tweak it to 350 using the franco kernel app?In the app you go to the kernel download tab where you can see the latest 'nightly' available for download. If you want this then tap the download and choose whether to auto-flash or to download the .zip file. The latter you need to flash in a custom recovery. If you are familiar with custom recoveries then I'd suggest you take this route and make sure you clear Dalvik cache before flashing the .zip. That's really it. When you reboot you can then set the min and max values of your CPu through the app and enable for it to be set upon boot. All things said your device must be rooted for all this. I'm running mine very stable at min 350MHz and max 1305MHz.![]()
Choose one of the Francisco power profiles and leave it at that. Leave the governor controls alone.
