davoid
Android Expert
On quadrant im getting 6042.
I use both those benchmark apps.
That's pretty good. Have you overclocked it yet? If so what frequency?
You will get another boost if you change to ART (in developer settings), and if you aren't overclocked yet, you will get another boost yet.
Here is mine (on ART):
And here's another benchmark with ART and OC to 1600MHz:
Although It's not really beneficial to compare my benchmark with yours, it is quite useful to observe the effect of different tweaks on your own phone.
If you are considering using ART (Android Run Time) which is experimental and only available on Kitkat roms, have a little read about it.
http://androidforums.com/android-lounge/792223-introducing-new-android-runtime-art.html
Although it's experimental and some apps don't work with it enabled, I have it enabled all the time and it makes my phone faster so I don't need to overclock
Warning (sort of): if you enable it in Developer Options, you need to reboot your phone and then Android rebuilds all your apps to work on the new runtime, and this can take about 10 minutes if you've got loads of apps installed. It only has to do it the first time though. Subsequent reboots are quick.
