Okay, guys. Here's a JC6 firmware with removed CSC and integrated Recovery 4.6.2.
All you need to do, is to put RECTOOLS.tar.gz (included in the archive) on your internal SD card and flash the firmware files with Odin as you normally would. No fastboot needed.
[the file was corrupt. re-uploading]
P.S. I don't know if you can use the altrered PDA.tar to restore G.Apps, perhaps it will not pass cheksumm check. So if you are going to install Galaxo 1.6.2 and need to restore G.Apps - use the original PDA.tar for that.
Instead of CSC , are we using RECTOOLS.tar.gz ??
I flashed JC6 before with
I7500SERJC6-CSC-CL209906-SER.tar and not having RECTOOLS.tar.gz on SD card.
Now i flashed with RECTOOLS.tar.gz without I7500SERJC6-CSC-CL209906-SER.tar.
what difference i could make now ?
