Quick question i am on the latest software is there Amy way to install the jellybean and keep my current data and pictures etc so i don't gave top redo my user data thanks.
Copy your pics to an sdcard and make sure your contacts are synced to a Google account. Then either back your apps with Titanium backup if rooted or re-download them (Google remembers any apps that you bought). I wouldn't recommend doing a no data install if going to JB from ICS
No, if you are on ICS wanting to move to JB it is best to do the full restore install. There have been many changes between the two, not just visual but inner workings as well. The full restore and the no data install are 2 different install option for the One click install for the stock rooted/unrooted installs of JB. If going to install a custom ROM then follow the instruction for that ROM.
So its best to start from scratch then and restore my data my self
yes when moving to JB from ICS
it is not too bad when you have an sdcard and sync your contacts
where do I get a modem for jellybean GA10
Thank you I must report that installing the jelly bean update my speeds and signal have dramatically increased and the phone has much better performance overall this was much needed thanks again everyone
nevermind, A little reading all you need to do
Because its not when he put tge inverted playstore in the gapps zip it wouldnt install right. He told us in one of the first pages of the thread.
I am considering installing the pac in black aosp rom. I just rooted so I have the agat kernal and recovery. Do I need a different recovery/kernal? On xda, it says to boot into a safe recovery, preferably EL26. What does EL26 mean?? I am new when it comes to all this stuff. How do I tell what what numbered recovery I have, I looked into about phone but could not find anything that says EL26?? Please help
Ok first let me tell you the recoveries are packed into the kernels. EL26 was a Samsung Rom on ginger bread like FL24 is a stock Rom on ics.
But you are only flashing the kernel because the recovery that lies within is deemed to be safe. You cannot use el26 on your phone all the time because we aren't using gb. But you flash it. Then flash a rom in it then it's replaced with the correct kernel and recovery that was in the Rom you flashed..
Basically if you follow the instructions to install each Rom you'll be good.
Sorry, but didn't it say on the pac in black xda thread that to use kernel el 26? But you said that's for gb. Isn't pac in black a jb rom?
