Are these adjustable with setcpu?
I flashed with an earlier 1.8 OC, what do I gain by using this one?
Its built with the new MB3 update source, and I changed the default I/O scheduler to deadline which gives a decent boost to performance as it is optimzed more towards flash based (out internal phone storage is flash storage).
Also its worth noting: since I've upgraded to the MB3 update on stock, I have not had one random reboot, which I had quite often before. So it seems they finally fixed whatever was causing the reboot problem (could have been a memory leak in a platform application; may not even be in the kernel)
Its your preference, but If you ask me I would recommend you flash the new MB3 based build. You won't regret it![]()
I also had the random rebooting problem too. Flashing the baseband is not an option since I am running the PartyTime JBS ROM, which coincidentally fixed the rebooting issue.
UPDATE: I downloaded the file you had on Dropbox, when I flashed it, it told me it was overclocking to 1.4
Nice kernel for stock MB3 rom. Thanks for putting this out.
I've always been skeptical about overclocking to the max so I'm eagerly awaiting a newer 1.4GHz version... but ill stick with the 1.8GHz/badass/noop for now.. =]
Just don't want to wake up one day with a broken phone.
animania260 I have to say that I really appreciate your hard work and determination on getting these kernels together for our Rushs, I'm really impressed with what you have done, your contributions to this device are greatly appreciated, I'm getting another Galaxy Rush on the 1st of next month so I'll be rejoining you guys by then... Keep up the good work, just amazing!!![]()
EDIT: And they both are 4G LTE devices, weird considering that the GS2 isn't LTE just 4G lol!!
(Had to add to my previous post this way since I have no edit button)![]()
Yea, I keep my eye on that thread also but my main question on porting it over is...Are they building a new kernel or are they using your kernel?
Here's linaro benchmark test app
https://www.box.com/shared/efaw3d034ien6iukyk62
