error 404 page not found for your V1.6 1.4 kernel
#!/system/bin/sh
# auto zram activation init script with busybox search
# by show-p1984
echo "[90ZRAM]: Firing up /system/etc/init.d/90zram";
if [ ! -e /sys/block/zram0/disksize ] ; then
echo "[90ZRAM]: ERROR unable to find /sys/block/zram0/disksize";
echo "[90ZRAM]: Is this a ZRAM kernel?";
echo "[90ZRAM]: ZRAM NOT ACTIVATED. (404)";
else
#find busybox in /system
bblocation=$(find /system/ -name 'busybox')
if [ -n "$bblocation" ] && [ -e "$bblocation" ] ; then
echo "[90ZRAM]: busybox found in:" $bblocation;
echo "[90ZRAM]: Setting ZRAM disksize.";
echo $((64*1024*1024)) > /sys/block/zram0/disksize
Nvm guys sister at hospital (pregnant). Probably tomorrow for the updates.
Updates coming guys, working on some goodies.
For now I have updated the link for the 90zram script. I reduced the amount from 64MB to 32MB. This works better on our phone, and really (unless we had like 4GB of RAM in our phones) the amount shouldn't go above 32MB anyway. Even 16MB would be okay.
Here's the new script: 32MB 90zram script
Also you can just edit the script and change where it says 64 to 32 instead of redownloading. Just make sure you don't change anything else.
Like so:
Change the red 64 to 32. Simple as that.
The official Google app: Sound Search for Google Play (for songs/music that was only officially available on Jeally Bean+ ?) is now available for install via the Google Play Store
Finally I can use this awesome widget on my phone!
You recommend changing the number to 32, I want to know what will happen if I try 16?
How can I tell if zram is automatically starting up at boot?
Congrats, if your sister is in the hospital already I'll bet she can't wait for it to pop out too!Once the phone boots just open a terminal app and type 'free'
If you see 0 at the bottom number then the script did not automatically run and zram is not active.
I have not been able to get it to work/run on boot. But I'm making a simple script that will run at boot from another script that is executed every time at boot in the ramdisk. I'm testing it tomorrow and it should work no problem, so hopefully update tomorrow with that and maybe a few other things.
And thank you Krize! My sister 2nd child, but first boy!
Can't wait for this little guy to pop out![]()
Yeah I haven't had any luck with zram running on boot, I just keep activating it manually when I reboot.
i downloaded both 1.6 kernels and both say its 1.8.. and 1.4 will not change from 1.8ghz in no frills cpu settings. sorry if this has been answered i am unable to navigate thru messages on my phone. thank you guys
Wow!! Very nice job on your work with these kernels animania260, you remind me of the latter day Kumajutsu on the original Prevail forum, you just keep'em coming lol! I don't know where you got all the knowledge to do this stuff but you seem to be doing it pretty damn good!! You have indeed opened so many doors with your latest contributions and I'm quite sure that everyone in this forum really appreciates all the hard and determined work that your doing with these kernels, I for one wish that I still had a functioning Rush as I would be working directly with you as an apprentice to try and harness your skills and knowledge to put it to good use for Android far and wide, good luck with your latest ventures and just know that your efforts are greatly appreciated...:car:
