Update-
Added the ROW I/O scheduler by Qualcomm - made specifically for mobile devices - and made it default.
Updated version to 4.1 - only did the 1.4GHz version. I got to re-compile a new 1.8- I'll do it later.
Running pretty damn good with this. Enjoy!
Is anybody having Wi-Fi issues with the last 2 builds or since ROW has been implemented?
No WiFi with 1.5. Errors out. Worked the previous builds
so i noticed the the zram is not loading after reboot i have permissions set with the script in the correct folder dont no if im doing something wrong but its not that hard to turn it on any way dont mind doing it , its like purging the Nitrous line lol
Just a quick question, i had flashed the partytime rom that sported the 1.4 ghz clock and it seemed like my phone would heat up real fast from the littlest things. Is it always like that for you guys?
I did notice my phone been heating up ...thought was my case not letting it air out. But it didn't effect function
Flashing your phone back to stock will get rid of all the oc stuff. Are you actually flashing roms onto you phone through Odin? And not through CWM? Your counter must be at like 50 lol.
Just put up both new 1.8GHz and 1.4GHz versions!
Reverted the Urgent Request feature of ROW that broke Wi-Fi. I did figure out why it did and will try to re-implement it later.
Also I found a lot of other things I will be adding when I get the chance. Bug fixes/improvements and more features. So stay tuned, more and more to come![]()
