PlayfulGod
Extreme Android User
DISCLAIMER: This is a MODDED KERNEL! Use at YOUR OWN RISK!!! By using this, you understand that that I am not liable for any or all consequences of using this. If you don't know what you're doing, DON'T TRY IT. Use at your own risk!
Here ya go, a overclocked kernel for the LG Connect MS840.
Whats it got?:
- enabled the cpufreq settings up to 1.8Ghz
- edit the default.prop to allow root
- set adbd persist
- enable debugging by default.
This works ok I will see about pushing its limits a lil
Flash in CWM, no wipes required.
Plague_LGConnect.zip - fixed
They probably took out some key stuff by accident trying to hide proprietary stuff... wish the big guys would just open source all the drivers and stuff without messing with it first. It's not like they got anything to loose, except locking us out.
