Flashing ROM's and Kernels I understand, most of the rest of that is going to take a while to sink in.......
Yes, I have been running Mik2.55 w/ Aggressive Freedom 0.9 for about a week now, no other mods. All I did was flash the ROM, then flash the kernel, then run the phone. Haven't changed any settings, haven't downloaded any apps more significant than angry birds
Now if I and my Noobness understand correctly, the Aggressive kernel should save battery better than the More kernel.......because it 'Aggressively' undervolts the phone.....right??
All of that being true.......because these things are funny.....Simply flashing the 'More' kernel, or I was also looking at Chop Suey, might have the desired effect, right???
Thanks!
-HN
well you are coorect in about the voltages, but in practice kernels will have different effects on different phones. also eahc of those kernels may react differently as well. so if one does not work then try the next one down the line.
but i would also look into using setcpu in conjuction with the kernel. here is a guide:http://androidforums.com/evo-4g-all-things-root/210253-setcpu-guide.html
