Rxpert83
Dr. Feelgood
I know what I'm flashing in the morning
Originally posted by Ca1ne on Xda. Go hit that man with some thanks.
Make sure you have the latest info by visiting the XDA thread here:
[KERNEL][WIP] Enoch Sense Kernel v0.1 [AUG 3 2012] [ICS] [SENSE] - xda-developers
Enoch Sense Kernel
This is a little something I have been working on. My hope is to bring a decent amount of customization and abilities to this kernel as I progress in versions.
And please remember this is a work in progress, so please let me know your results.
What's in this Kernel
Features
Based on Stock 3.0.8 Kernel Source from 1.13 Build
Snapdragon Optimizations
Memory/Scheduler tweaks
Read Ahead Speed from 128 to 1024
Camera Flash will work till 5%
Enabled XZ Compression
CPU OC to 2.1Ghz
CPU 128Mhz enabled
CPU Frequencies UV
GPU OC to 500Mhz
FSB OC to 533Mhz
VFS_Cache_Pressure from 100 to 50
String Performance Boost
Gentle_Fair_Sleepers disabled
Memory Tweaks/Various Other Tweaks
HTC Battery Array Fix
XZ Compression Added
Governors
Smartassv2
Interactive
Conservative
Powersave
Ondemand (set as default)
Performance
Lagfree
Lionheart
Schedulers
sio
v(R)
noop
deadline (set as default)
cfq
Instructions
[S-OFF] 1.13 Based Rom - Flash the Enoch Kernel zip and it will keep the original ramdisk of the rom you are on and copy over the compiled modules.
[S-OFF] 1.22 Based Rom (Insecure Boot.img) - Same as above.
[HTC Unlocked] [HBOOT 1.12] Same as above.
[S-OFF] 1.22 Based Rom (Secure Boot.img) - Use fastboot to flash the Enoch boot.img, and use a recovery to flash the compiled modules if wifi breaks.
[S-ON] [HTC Unlocked] Same as above.
Pertaining to overclocking. If it sticks at 2.1Ghz, just use No Frills CPU to set your max/min speeds, and be sure to check the box in settings labelled Prevent Changes from other apps. And that should block any custom scripts/modules/apps from setting it to max speeds.
Credits
I am grateful to all, from the developers, to the end users who
provide the feedback and use what is created.
More specifically (in alphabetical order) I would like to credit
the following developers for their work.
deck, faux123, klin1344, LeeDroid, lithid, mdeejay
romanbb, showp1984, toastcfh
Also I would like to thank the alpha testers who kept me going
evo401 (a flashing machine)
thicklizard (then he made his own kernel, gg!)
PhxkinMassacre
volk9029
Disclaimer
As with all things, not every variant can be accounted for. Please use at your own risk. I am not responsible for any damages/bricks/etc that may accompany use of this kernel.
Bug Reporting
Post a reply in this thread or pm me, and I will do my best to assist and/or correct bugs.
Update History
v0.1 - Initial Release
Links
enochv01.zip
MD5: 19dc061ff1d09f98b76068758cb34033
bootv01.img
MD5: 12f4c8000f0a918b82ea8566a4934e5b
v01modules.zip
MD5: fb6a9623cf65622e15c9ab540781636d
Old Links
None Yet
Github
