Root Launcher opinions
I Prefer Go Launcher. Launchers are like everything else though what works for me may not work for you. So yeah trial and error.
1 size does not fit all :D
i like go launcher as well. for some reason i do not like adw. i used to like pro launcher but the go launcher feels smoother and less laggy then pro launcher.
+1 for Go Launcher...
I feel like it is the most complete launcher out there with it's own store and a ton of widgets, lots of customization options, and it reacts well to performance enhancements.
My advice would be to starrt with GO and then move on if it doesn't suite your taste.
When I'm not running Sense, I actually prefer ADW EX over Go. I picked up ADW EX when is was one of those $.10 apps, and found it to be much more quick and smooth compared to Go, which always seemed to lag on me after a bit.
And I am pretty sad that the dev of LauncherPro let that one fall so far behind, it still has a few features I loved that others don't -- it just doesn't hold up anymore overall for newer phones.
Oh, and if you want to mess with some that are completely different, check out Claystone and Regina. :)
