northernmoris
Will the removethrottle.zip work with the new 1.5? Thanks..
for heavy data users on unlimited data plans vzw throttles your data usage if or when you exceed 5gb of data....more or less slowing you down if you use too much ....this data throttle hack will prevent that from happeningnoob question:
what does this do?
But nice hack!yes very nice,,,to be honest at first i didnt buy into it or at least was never affected by it but was suprised when vzw released today that they will enforce it so its a handy thing to use if you get throttledOh, very sweet! Although I have never run into that problem...yetBut nice hack!
How do I use the remove throttle zip? just select update.zip or install zip from sd card?
I wouldn't use it.
I will most likely make a separate file for throttle removal and clock removal. Last time I did both throttle and clock removal in the same file, but I think some people only wanted the throttle removal while still keeping the clock.
Install zip from sd card.
That would be awesome, TY very much!
Love removing the clock and enjoyed the one you did for 1.0.
