digdug1
Android Expert
No, have not loaded setcpu yet.
you really need setcpu if you are rooted and running overclocked kernals
Loaded setcpu, set it to performance.you really need setcpu if you are rooted and running overclocked kernals![]()
Quadrant benchmark score: 1701 Temp 107
Set to on demand immediately after I ran benchmark....remember to change setcpu to interactive or on demand after testing....
I installed the Frozen yogurt first, then the tangerine, then chevys kernal. Now im wondering about a few things and have some problems on others. First, only 3 screens, instead of the five, or is there a mistake? and the bigger question is the title of my thread, I cant seem to get my POP3 server email to connect. Its my school email address, and it worked before I installed these roms/themes on there. I actually had Smoked Glass with Chevysno1 LV 1100mhz OC before I did this install and my school email worked then. Any suggestions, especially since school is starting back up next week for me, I fell in love with the email on my phone.
the only kernal faster than this one is jakes newest 1.2. i get 1780's in quadrant and got 108 short bench with it! however jakes old kernals were not kind to my battery. not sure about his newer one. remember to change setcpu to interactive or on demand after testing. with these kernals and liquid this is my fastest most reliable set up yet.
Ok, n00b question, but do kernels install just like roms and themes? Thanks!
Have you tried Sayher's kernels?![]()
i like the new govenor feature. i get low 1700's with the lv1.2 and 150's short bench which is still great! this is my favorite kernal because it also has great battery life. however jakes kernals are a little faster but as i stated thay have always given me subpar battery life.This seems odd.. made a backup in Clockwork and then tried to install the ModWM.zip file. Clockwork will reboot, attempt to install the theme, but then go back to the Clockwork Recovery menu. When I reboot, it appears the theme wasn't installed. Tried this a few times with the same result. Not sure if anyone else was experiencing this, but I'm going to try and DL the file again and chalk it up to a bad download...
**UPDATE**
It isn't a bad download.. really not sure why this is the case. Any one have any ideas?
Pandora is saying it has an update. But it keeps failing to install. I'm assuming this is because Pandora is modded for the theme I'm running?
Yes, and if you were successful installing the update, it would break the theme for Pandora.
If you REALLY want the update, despite that it will break the theming for Pandora, you need to remove all vestiges of Pandora from your device. Here's a foolproof way to do that in terminal:
su
sysrw
busybox rm system/app/Pandora.apk
cd system/bin
sh pm uninstall com.pandora.android
cd..
cd..
sysro
sync
Still can't get the UBRocked's Blueberry keyboard to install. Changed the .zip file that downloaded to an .apk, then loaded onto my sdcard. When I try to use Astro to install it, it won't even open it in app manager. I installed another app installer from the market, and it says there is a parsing error.
The file that is downloading from here shows up as HTC_IME_Liquid_Black-Blue.apk.zip and is 4.5 MB. The mediafire page says its only supposed to be 4.33 MB.
slayhers kernals were the ones i was initially commenting oni like the new govenor feature. i get low 1700's with the lv1.2 and 150's short bench which is still great! this is my favorite kernal because it also has great battery life. however jakes kernals are a little faster but as i stated thay have always given me subpar battery life.
Here is a black bar theme for you
http://android.markjohnston.us/DL/LFY/THEMES/BlackBar.zip
That i just made for you enjoy![]()
Link is broken... searched this thread, couldn't find another link. Can you please fix? Thanx in advance.
The blackbar Mod has been removed (I'm not sure why).
Watermark'D is no longer hosted by Liquid. If you want the latest Watermark'D theme, visit the Watermark'D thread here
BlackBar.zipHave you tried resigning the apk?
Do you know if slayher's kernels support the wifi tether
and wired tethering root apps? Native to Froyo?
