Does anybody know how I can get back to the stock kernel after flashing a different one?
Is anyone else having the issue with the keyboard closing? when I try to text or sometimes search in google I get this error. The application Android keyboard (process com.android.inputmethod.latin) has stopped unexpectedly. Please try again.
It usually happens after punching in two or so letters... everytime... Maybe I did something wrong when I updated, I had a 2.1 rooted, and just used the liquid frozen yogurt 1.4 to install it via sprecovery. Then i did the 1.41 update.... Should I have not done it that way coming from a rooted 2.1?
Having market issues. Either slow to load or not at all. Any suggestions?
WaterMark'd theme is giving 404 errors - could you please disable the link in the OP until it is back up (I assume that you're working on getting the SS image thing fixed)....
Sure seems people are having issues with this ROM, I have had none of these symptoms at all. Knock On Wood
Does this ROM have the Stagefright fix code from Google that allows AAC+ decoding to happen properly (i.e. Pandora sounding good again)? Thanks!
I'm looking for ROMs that have that fix. Currently all i know of is Simply Stunning 4.7, but i also want a rom that has really good battery life and I've heard mixed reports about Simply Stunning.
Thanks![]()
flashed this last night and im loving it. is there any way to get the horizontal battery w/ percent like in v1.3? and thanks for the black notification zip, awesome!
Just thought I'd post a few additional screen shots. I love the theme choices and he's an idea of what they look like up against the same background with some custom Launcher Pro setups
i installed this rom and patch. i then installed the htc keyboard provided by ubrocked. and all was well. then i decided to install the modified watermark'd theme provided by bemenaker:ModWM.zip. for some strange reason, i noticed that the droid two keyboard is working now which is weird because i deleted it with root explorer. the one ubrocked provided is still an option to use as well. did this theme undo the patch or did it fix the keyboard? should i reinstall the patch?
I installed this rom yesterday and then tried installing the orange skin. When I installed the skin, my phone went into a constant that I couldn't get out of. I had to use the rsdlite recovery to get back to stock. Any ideas why this happened? Do i need to have the launcher and everything installed prior to installing the skin? This was my first attempt at root and roms and such, so I'm not the most knowledeable on the subject. Any advice would be appreciated.
Please send me this background. It's awesome. I'd really appreciate it. Thank you in advance.
