LiQuID FroZeN YoGurT v1.4 (FRG22 Custom ROM Built From Source!!!) *Updated Patch - OTA Update Fix*
Poll closed due to new release for this ROM
  • 5 Star ROM Rating: Elite
    Votes: 70 79.5%
  • 4 Star ROM Rating: Outstanding
    Votes: 13 14.8%
  • 3 Star ROM Rating: Average
    Votes: 2 2.3%
  • 2 Star ROM Rating: Not Ready for Primetime
    Votes: 1 1.1%
  • 1 Star ROM Rating: Not Usable
    Votes: 2 2.3%
  • Total voters
    88
Status
Not open for further replies.
Also, my wifi doesn't work. I've tried it on SS v4.6 and it doesn't work. I am using the stock kernel that came on this ROM...
whenever I try to connect it says: Obtaining IP address, then it says: Remembered, Secured with WEP.
It just won't connect. I've typed in the password and everything...wtf
The multitouch keyboard screws up my hardware keyboard. If I click alt once it locks into alt mode. The only way to keep it from doing this is to disable the mutitouch keyboard.
Can you please post a link to the stock android keyboard so that I have some form of software keyboard?
Hey UBRocked, any way you could post the tangerine dock you have going there? Or at least the icons?
UB, better than the dock, where'd you find that lovely wallpaper?
Here is the dock image:
http://www.mediafire.com/imgbnc.php/1f62921d3a7b0d79c6a34e9ac1bb31856g.jpg
Wallpaper can be found here:
Android Wallpaper - Category: Women - Picture: girl headphones
I bought the $1 LP Icons app and that (along with the DroidX app drawer icon) can be found here:
Most Recent Icons | LauncherPro Icons
(all the other docs except for the tangerine one I posted can be found here...I had to tint the green one orange to make it work)
Evo Text Icons can all be found here:
http://androidforums.com/roms-droid/145056-theme-bugless-evolution.html
Anything else? :D
has anyone used their camera yet after installing this rom? open your camera and then hit the "focus mode" button, mine force closes if i hit the focus button first.
Yeah, I've used it quite a bit. Before now, I never hit the focus button "first thing" after opening the camera. I've been playing with it for about 10 minutes and can't duplicate your problem. Is it something that happens every time?
yep everytime and it also does it on the camcorder hitting the same button aka "color effect" this is a screen shot of after i do it.
I'm also unable to duplicate the problem. The focus mode works just fine for me when I tap it first thing after opening the camera. It must be a compatibility issue with another app, or even the kernel you've chosen. I know it might sound weird that the kernel is the issue, but I just discovered last night that it was the P3Droid kernel I was using that was causing Goggles to force close (same result with Slayher kernels, but ChevyNo1 kernels don't cause the problem).
To troubleshoot my Goggles problem, I did a nandroid backup of my setup, wiped my partitions and loaded the naked stock ROM, then added nothing but wifi and Goggles -- Goggles worked. I then added just my theme -- Goggles worked. I then added the P3Droid kernel I was using and Goggles immediately FC'd when I tried to open it. Next I loaded a ChevyNo1 kernel and Goggles worked. I loaded P3Droid and then Chevy again to verify the result. When I tried the new Slayher kernels later in the evening, Goggles FC'd again. Maybe you could troubleshoot your issue in a similar fashion.
Good Points!
Also, you could try to go into ROM Manager > Scroll down to "Utilities" > Select "Fix Permissions". I know that this fixes some FC issues.
it wont let me remove launcherpro, it says its read only. i dont like the orange icons but other than that love this rom
Try typing:
su
sysrw
rmlauncherpro
sysro
and see if that works.
Or, if you have Root Explorer, just go to /system/app, tap the "Mount R/W" button at the top, long-press on Launcherpro.apk and delete it, then tap "Mount R/O."
Alright guys, been running 1.4 with Watermark'd for a day now and love it. My only complaint, and it's a little cosmetic one, is that the back ground for the in call screen has Chevy Symbols on it. Is there anychance someone could either remove them for me or tell me how to do it. I'm not much of a chevy fan.
Thanks in advance!
Thanks in advance!
Yeah, this is a known Watermark'D theme issue with this ROM. The Watermark'D theme was not updated for this ROM prior to Liquid releasing it. Liquid used the updated Watermark'D theme for Chevy's ROM as the base theme so you could have the upgraded things in the Watermark'D theme (like the lockscreen for example). Problem is that some of the "Chevy" specific backgrounds and logos were left behind and not noticed prior to release.
Liquid is aware of it but I'm not sure what the immediate fix action will be.
I see that GirLuvsDroid has posted the stock android keyboard (Thanks GLD!). If you like that stock keyboard...installing that will solve your problems. If you want a themed HTC_IME keyboard instead...give me a few and I will be posting a Tangerine, Blueberry, Green (probably used for the smoked theme), and Red themed versions (cause everyone could use a splash of Red every now and again :D).
Try typing:
su
sysrw
rmlauncherpro
sysro
it worked! thanks so much.
just out of curiosity, what do sysrw and sysro mean?
Ok...I just finished installing. Seems very nice and fast thus far. I have one issue though...what happened to the 3D rotating app drawer. I LIKED that....but I can't find an option for that in here anywhere. Am I missing it?! TIA
I copied this from the 1.3 thread cause I thought it might be helpful information...
haha true. thank you. man was i tired at 3am when i posted that last night. i was just reading through the thread again this morning and saw my answer a little way up the 3rd page. def didn't see it last night when i was looking.
the more i get using this rom the more i love it. again i'm new to this game, but my battery life has been badass, AND everything is much quicker then the ota stock froyo update. and it looks way sicker of course themed out in black. i thought of another question while i was sleeping (and dreaming in android..) - if i want to change themes from smoke to tangerine (for example) everything will be fine if i just flash the tangerine theme, correct? or do i need to go through clearing data, flashing the rom then flashing the theme again..? thanks in advance for the sick rom liquid. i am now officially hooked on mod'ing my droid..
First of all...If you are discussing the 1.4 version of the ROM (that supports the tangerine theme), you might want to move this conversation to the 1.4 thread ;)
Secondly...If you are running 1.4 and you are running the Smoked theme...you can change to any of the other themes. Adding a theme doesn't require you to wipe data or anything like that....but there are some considerations you should be aware of.
For example: If you are running Smoked theme...all the other themes can be applied over it and it will be just fine. The smoked theme is the "least themed" version. If you were to reverse it and load the tangerine theme FIRST and then try to go to the Smoked theme, you would be left with the Smoked theme and several Tangerine themed icons :eek:
Best Practices: When you load a ROM with multiple themes available you should get all your apps, settings, etc setup just the way you want it on the Stock theme. Then you want to make a backup (this is very important). Now, flash a theme. If you don't like the theme or just want to try a new one, restore your "stock" backup and then apply the new theme over that. This ensures that the theme will work flawlessly and you won't have little bits of multiple themes overlapping each other.
I dunno if its just me (and it probably is), but I'm having serious issues with streaming Flash audio with LFY 1.4. I've tried using yourmuze.fm and a local sports radio site (sportsanimal99.com) and, oddly enough, the ads from sports animal play perfectly, but when I get into the actual stream, the audio plays in slow motion. The exact same thing happens on yourmuze.fm as well. I was able to stream without a problem on a couple of earlier ROMs (BB .4 and Lithium from ROM Manager, I know for sure).
I'm currently in the process of restoring a nandroid of Sapphire that I made to see if I have the same problem with the same version of Flash i'm running on LFY. I reaaaaally hope its a problem with Flash and not somethign weird with my ROM install, because I absolutely love your ROM. Even talked my fiance into letting me root her phone because she was amazed at how fast and nice looking everything was. She's now among the "elite" with a rooted Droid using Liquid Tangerine =)
I'll report back with what I find from Sapphire.
**well, after restoring to Sapphire, all the streams I tried sounded normal. Gonna rip my Flash APK and make sure its the same version in LFY and see if that makes a difference at all.
**well damn, it doens't make a difference. I'm running Flash 10.1.72.7 and it 100% works on the latest Sapphire. Anybody got suggestions of what I can try? I really want to use LFY, but I gotta have my streaming fix during the day. =(
There is a setting in Launcher Pro which allows this go to Launcher Pro Preferences. Advanced Settings 7th row from the top should e the option to have a 3D Drawer.
And UBR, my friend's software keyboard is unresponsive on the last row, he is stock 2.1 Do you think reinstalling that apk you posted solve the problem?
What ever happened to the option of putting your phone into silent mode (no ring or vibrate) by pressing the ringer volume one below vibrate? I can only get my phone to either do a silent (no ring) + vibrate or silent + no vibrate. Am I missing something? or is this missing from this ROM? or Froyo 2.2 in general?
Status
