LiQuID FroZeN YoGurT v1.5 (FRG22 Built From AOSP Source!! - Custom SLaYHer KeRNeLs!!)
Poll closed due to new release for this ROM
  • 5 Star ROM Rating: Elite
    Votes: 48 60.0%
  • 4 Star ROM Rating: Outstanding
    Votes: 20 25.0%
  • 3 Star ROM Rating: Average
    Votes: 3 3.8%
  • 2 Star ROM Rating: Not Ready for Primetime
    Votes: 5 6.3%
  • 1 Star ROM Rating: Not Usable
    Votes: 4 5.0%
  • Total voters
    80
Status
Not open for further replies.
Liquid has worked on this all day. Thanks to Stewart for the theme...thanks to Liquid for updating the theme and porting it to 1.5!
Watermark'D for LFY1.5
I will edit the OP so this theme is available for download there as well :cool:
I love Watermark'D! I switched my kernel to interactive and turned off campache, now it's almost as great as 1.4. Almost because there are still some random FCs. Can't wait for 1.6.
Even after I dumped compcache, I'm having to re boot at least once a day, or things get buggy. Bluetooth shuts off by itself, home screen takes 3 to 5 seconds to show apps, things like that
So I have given up on compcache, after 2 days of use without rebooting my phone slows way down. So much so that I can not always unlock the screen while listining to a podcast, if I get a text while another program is going on my phone locks up and takes its sweet time to let me do anything. A reboot fixes the lag problems completely but when my phone is working fine before work and then 3 hours into my work day I dont want to have to reboot. I love slayher's kernels they work great on my phone, run cool and smooth as a baby's behind...but compcache has lost my blessing.
I ran the script for removing compcache, but didn't see any confirmation that its gone- can anyone say if there is something, and if so, what does it say? Possibly the issues I'm having are because I didn't get it removed...
type "compcache stats" in the terminal. If it is on you will see some stats. If it is off you will see "Failed to open...."
Went to the All THING root sticky..and I coulda swore they used to have a "how to flash themes" thread.. but i cant find it.. I know its pretty simple, but this will be my first theme flash and I want to follow SOP! ANyone have the correct steps?
You can do two things. Easiest one is to download ROM manager, allow it to flash clockwork over SPRecovery and select what you want from the list of ROMs, it will do the rest for you.
The other way is to use SPRecovery(or Clockwork)to fkash them yourself. Download the ROM on your computer, transfer it to your Droid through the USB. Just drop it on the phone, not in any folders, and rename it "update"(doesn't have to with Clockwork). Disconnect, then power down. Hold X and power up. Make sure you select both Wipe Cache and Wipe Data. Go down to install update, then hit allow update.zip, then install update. Wait for it to finish, then hit power once then reboot. It'll be flashed with a new ROM. Since it is Froyo you should get most of your apps back. For txts you can get a backup app that'll back those up before you start.
uhh.. this is for new roms... im lookin for themes. I know you just flash over without wiping..but isnt there a backup you should do?
Other than "fixing" that little lag when loading your home screens. What exactly does this command do to the phone? I'd like to know why it fixes it, not just that it fixes it. I kno, somewhat of a nerd thing right?
Yeah, you should do a nandroid backup first or use rom manager to do a backup. Use rom manager and select backup current rom. Then flash the theme as you would any rom, but do not wipe anything.
I just flashed the new watermarkd theme and everything looks good so far. At first it got stuck on the blue eye screen but I did a reboot and everything worked as it should. I will see how things go for the next few days. Thanks for making this theme happen.
Ok....i've used several of liquids roms...and this one worked very well as did his previous ones for me. I loved it...very smooth with slayher's kernel. One MAJOR problem, and I've seen it mentioned a couple of times with no answer.....bluetooth voice dialing is a MUST for me. So much so that I switched roms because it doesn't seem to exist in this ROM. I get absolutely NOTHING when I try to initiate a call with my BT headset. Did I miss something here, or is it not possible with this ROM??
I am so glad to hear I am not the only one having this problem! I removed the bluetooth relationship on both the phone and my car's headunit and re-added them but it says voicedial is not supported.
Also, when I used Navigation it said TTS wasn't installed, I guess I've been spoiled by other roms because I've never gotten that message before. Which TTS in the market do I need to install?
I got the same TTS issue. It told me that I needed to download from the market, and it linked to the market for me...so I just downloaded/installed the one that popped up there. Then it worked fine.
However, I still have NO idea about Voice dial :(
Me too. Also, how to reverse it if necessary.
Question about theme. Currently I am running the smoked theme, if I want to flash the watermarked theme do I need to do anything certian? Factory reset or reflash the stock LFY rom?
Anyone?? Voice-dial with bluetooth?? Man I miss liquid....I've had to temporarily switch ROMS because i NEED to be able to do this. I want to come back :)
To reverse you just need to open the /data/local.prop file and remove the line you've added by running the echo command.
Open a command prompt/console window.
su
sysrw
vi /data/local.prop
Move the cursor to the line that reads "ro.HOME_APP_ADJ=1"
D
ZZ
sysro
exit
exit
Note that the D and the ZZ must be capitalized for them to have effect. You should see the line disappear altogether when you do the D, and then return to a command prompt after typing ZZ.
After that, reboot your phone and you should be back to normal.
My understanding from Samsonite801 is that this forces the OS to keep your launcher/home in-memory. I know with LPro you can set it to stay in memory, but the results have been iffy. This, apparently, forces it to stay resident in memory.
You can read about Samsonite's journey of discovery here.
I decided to try Slayher 1200 kernel and my phone did not like it.It decided to go into continuous reboot loop. I then re-install the old rom with the P3 kernel and everything back to normal so far.
Don't know if this has anything to do with the rom or not, I have noticed that Set CPU is not loading on boot. I am currently running LFY 1.4 Watermarkd theme with one of Slayhers kernels. Yes I do have the Start on Boot checked.
Not a big deal, but it should be working though...
Status
