Sounds more like a baseband issue than anything else - what baseband are you using?
It is C_01.43.01P
I feel the need to come back here and express something that makes me a bit shamefaced.
I had read a bit here and there about the Slayher kernels and the new 'interactive' Scaling method. Of course, I didn't try it - but I just read a post on here where a user said it made a huge difference.
OK, WTH, let me try it.
All of my lagginess has gone away. As in pulled the best harry Houdini I have ever seen with my own two eyes. As in "Wow, I should bottle this stuff up and market it to Jenny Craig and Weight Watchers! I'd be a gazillionaire in 2 days flat!"
Up until now I have been running the stock kernel b/c I simply have not had the time to try out a more powerful kernel - and I was getting frustrated beyond measure at the issues I had with the ROM:
- Twitter app always forgets my login upon a reboot / battery pull (and I am performing battery pulls not b/c of issues, but because battery drain was rather high, see #2, and so I was physically replacing the battery with a fully charged one).
- The battery life has gone to horrid on my phone - I cannot get 6 hours of a day, an this is with advanced profiles in Locale turning things off that I don't need (a first for me since I moved to FroYo).
- On every boot, the phone is laggy as HE|_|_!!!!!!
OK, #3 is dead, hopefully #2 will be as well, which leaves me with #1 - and the fix for that is simple - remove the twitter app that comes with the the Smoked theme and install the default Twitter app....
So, all in all, LFY is once again an awesome ROM on my phone.
Now, if I could just get my hands on LFY 1.6.....![]()
i'm just curious how many times did you wipe
each type of partition?
I'm just curious how many times did you wipe
lololololololololololollolololololololololololololololo
SigmunDroid...I don't think he's laughing at you...there is a back story here and some friendly disagreement about wiping partitions multiple times and whether or not it is actually better than wiping once. Haha!
http://androidforums.com/droid-all-things-root/98166-once-twice-three-times-lady-wiped.html
LMAO... You know, this is flash memory we're talking about. Theoretically, once a bit state has been changed to 0 or 1 it's permanent (minus the effects of extreme age without any applied power). This isn't like a HDD where heat can affect the stability of bit states (See superparamagnetic effect).
I suppose it all depends on the level of wiping it's doing. If it's only wiping the partition table, the data is still there; the OS just can't read it because it has no reference on how to convert the string of bits into something usable. If it's actually rewriting the partition with all 1's or 0's (essentially a full wipe) then there's no data there at all. In either case, you should only have to perform the wipe once. The only way you'd need to do it again would be if the utility performing the wipe is wholly inadequate and isn't doing its job.
Just flashed the rom. I love the layout< well what I can see of it. I dont have a settings icon or can get into my phone settings to click on to allow me to restore all my apps and settings. Any ideas?
I am looking forward to 1.6 as well it should be dynamiteright uB ? lol
Quick question, if I disable the compcache, do I need to change the setCPU setting from interactive to ondemand?
Sorry, I am pretty new to all this.... Thanks for all your help!
Bump, does anyone have any ideas. or am I looking in the wrong place. I have no way to get into the settings at all so I cannot click the unknown sources to install my apps. I did the download through the rom manager, everythign seems to work fine except the fact I can't get any of my apps. ALso can't always get into the market it force closes.
do you have an idea when you will release 1.6?I am looking forward to 1.6 as well it should be dynamiteright uB ? lol
Review - Liquid Frozen Yogurt 1.5
Installation & Setup
LFY 1.5 installed as expected. This rom possibly has the coolest boot animation I
Sorry Wags, I really am not understanding what you are talking about
Are you saying there is no settings icon in the app drawer? Can you press your menu button and then click settings? It's the same thing.
Correct there is no icon in app drawer and I tried to press the menu button and then click settings and it does nothing. I cannot get into the settings at all. I dont know why. I installed it through the rom manager and it installed fine, booted up fine, I just cannot get into my settings.
how do u disable compcache?
