bjanow
Android Expert
[Rom] *** Liquid Smooth Roms 3.1 For Multiple Devices *** - RootzWiki
Find the Easter egg for ICS. Took me a while but it was late.
Fancier, no sense. Runs really fast, ICS stuff in there, just a fun rom to play with overall.Still have not tried out this ROM. Been using CM 7 as my daily driver. Might have to give this a whirl for the hell of it.
This ROM pretty much just a fancier AOSP ROM or does it have Sense stuff in there somewhere?
Reboot if you still get the FC then reboot recovery and fix permissions. If after that you still get FC go back to the stock status bar
No good, tried going back to the stock bar but I get the same results.
I set up 3.1 tonight. Wiped everything possible and its pretty smooth and quick. So far so good.
Only thing I've noticed and I haven't been able to fix it, is a couple apps are showing menus floating in the middle of the screen. I got the MIUI camera working, but GO Weather still has the forecast floating in the middle of the screen.
Can you make a screen shot? I've heard other people talk about this in the past but I haven't seen it
Is the new market included in this rom?[/QUOTE said:No - You have to load that separately. Still a smooth work so far! No issues for me so far.
