Motorhead1991
Android Expert
What carrier are you using?
alright, now i have an issue, I accidentally deleted my stock ROM, does anyone have it?
Try killing any other running apps and trying again. As for your ROM question, one.three and my MH-1.0 are faster than stock because they are slimmed down, and de-odexed.
I'm running Go Launcher Ex. I went into the app drawer and clicked on running apps, then killed them all. Tried again and got the same error.
I would just boot into recovery mode and do it that way, but I don't want to have to wipe my settings to do it.
EDIT: I got it. I downloaded Advanced Task Killer and shut a bunch of crap down!
EDIT2: Just installed one.three, I'll post if it all goes well.
All files were downloaded per your instructions. I'd also tried the other person's instructions on this site when they first appeared. Yours were clearer to me because I'm new to rooting, etc. Anyway, as u can see, it still stops at step 10..."no such file or directory". I've attached just in case screen print. Thanks8. Paste this command and press enter (it just
removes log_kernel.txt, that's all)
rm /data/local/logs/kernel/log_kernel.txt
press "enter"
9. Paste this command and press enter, it
creates a symlink. If it gives you an error
message, that means this all has been done
before. It may say "already linked" or something
similar if you've already done this and are
starting over.
ln -s /data/local.prop /data/local/logs/kernel/
log_kernel.txt
press "enter"
.Symlinking is OK. I still can't create #10...ls -l /data/local.prop.@dinat411:
Try skipping step 8, it looks like it's trying to symlink to a non-existant file. Worth a try.
.worked fine for me, took a few tries, and a couple of tweaks for my phone, but i can use everything(minus 3g), i have a feeling i jacked something up there though. it's not showing my network as att, or straight talk. trying to find the problem on the forum. elsewhere, will post it when i find it if anyone else needs it, but as of time now, no one else has stated anything about the problem so i assume it is me
Edit: i also have a second completely stock, never activated merit that i can try and root and pull a ROM off of(i have no idea how to post it so if someone wants it i may need to mail it to OP for posting)
No hun, you've been nothing but nice and thankful...it's a no-account user with one post that was giving me a hard time.
The rom I'm currently using is for a zte v860 and the built-in FM Tuner app keeps saying it "has a bad signal" and I can't tune into any local stations (but I also can't tune in via my living room radio without a large antennae) so when I get a chance to test it in town I'll report back about it. I'm pretty sure the ZTE Z990g version (which is what I have) has a radio inside of it but of course they don't exactly avertise that and have no app to operate it.
The only bad thing about the FTM mode is that I have the choice between leaving that along with the stock recovery OR reflashing to cwm and loosing the ftm. I see no use in the FTM for this particular phone so I've gotten cwm back. I guess if it was ever needed, I can just use the stock recovery image from this ROM or whatever.
