ok I'm totally new to this and just got my first android phone, I want to root it because i cant believe it doesnt have more internal memory, and I want to get rid of some of the factory apps that came with it to free up more space as well as move some of the unmovable ones to the sd card. i believe from what i have read rooting will allow me to do this... ok I have the zipped dropbox file do i install it on the phone zipped? so i can open shell
I felt the same way as you and it was my first android as well and not to mention my first root ever! Just follow Krystals guide to a "T" and you'll get it up and going in no time! As far as your question about the zipped file, you wanna leave all files in their zipped to root!
(All this is in Krystal's guide I just wanna make sure a newbee hears it 2 or 3 times before they start like I did! Cuz it helped!!!)just wanted to say thanks,, I think i will attempt it this weekend.. ive been watching and reading this for 2 days trying to decide if i wanted to try it, but just cant handle only being able to have 2-3 apps and phone starts saying low memory, when i have a 32gb memory card and can only put certain apps on it..seems like all the apps i want have to stay on internal memory..lolYup this will alow you to do what you are wanting and leave you quite HAPPY!!!I felt the same way as you and it was my first android as well and not to mention my first root ever! Just follow Krystals guide to a "T" and you'll get it up and going in no time! As far as your question about the zipped file, you wanna leave all files in their zipped to root!
After you root, install superuser app, and clockwork mod make sure to backup your current ROM first with clockwork before preceeding to install the one. three rom. That way you'll allways have your stock rom and you can NEVER screw anything up from that point forward!(All this is in Krystal's guide I just wanna make sure a newbee hears it 2 or 3 times before they start like I did! Cuz it helped!!!)
Good luck!
-Chud-
You'll get it done and you come out saying DAMN that was SO EASY!!!
HANG HERE EVERYONE is VERY HELPFUL!!
I had the same issue...tried many times. Finally rooted after "factory reset" (under Privacy settings) then I followed the steps in Ziggily's 7/7/12, 11:25pm post. Good Luck!I went through all the steps everything seems fine, however I am getting Sorry! This device does not have proper root access. With Root Check Basic as well as when I run Superuser under info it says su binary not found I do not understand what I am doing wrong. PLEASE HELP I have tried this at least 15 times THANKS ANYONE !
help pleaseexcuse the dumb question but what adb tools do i need to have installed on my computer to do this?
i keep running into reboot: operation not permitted on CMD shell, i cannot for the life of me figure out why,probably because i have no clue what i am doing, but still, lol.
hello all. obviously new here. I've successfully rooted the zte merit. I installed ROM Manager, and when i tried to back up my ROM, it tells me i need to install CWM Recovery. I click to install, and it asks me to Confirm Phone Model, but there are no ZTE's in the list. what do i do now? Thanks.
CWM Recovery is a seperate image for these phones. Search the 2 (all things root) pages dedicated to the Z990# series of phones for it. ROM Manager has been shown to brick devices, so no one really uses it.
come on someone, anyone, I know this is a stupid question and it has probably been answered a hundred times and you dont want to have to answer it again, but i have done a search and read everything i could find on the merit and still havent found my answer, i can get to shell but want to make sure i have everything i need before i get started, i read i was supposed to put the su file in abd tools folder but cant find it on my comp. so want to know if i need to download something else..HELP PLEASEexcuse the dumb question but what adb tools do I need to have installed on my Computer to do this?
Next, open up command prompt and type
- adb shell
- press "enter"
- reboot recovery
- press "enter"
It should reboot into recovery, use side buttons to navigate to "install zip"
After root, I bypassed flashing the rom and went straight for installing the one.three rom.
OK here's the problem. There is no "install zip" menu selection. Just something about "wipe cache", "wipe partition" and reboot. I have a Straight Talk ZTE Merit 990G that's been rooted via the Jcase method. Did the 'reboot recovery' thing twice. Never any "install zip" selection.
come on someone, anyone, I know this is a stupid question and it has probably been answered a hundred times and you dont want to have to answer it again, but i have done a search and read everything i could find on the merit and still havent found my answer, i can get to shell but want to make sure i have everything i need before i get started, i read i was supposed to put the su file in abd tools folder but cant find it on my comp. so want to know if i need to download something else..HELP PLEASE![]()
