airtioteclint
Android Expert
What's the change log for today's build ? It doesn't show up when I look
5.1 sound and $prompt command.
Is call volume ok on this built
I forgot to check I'm back on stock again. I rarely make calls but according to the comments in rom manager it was fixed a few builds ago.
Is anyone having this issue with WiFi tethering, where when you chose to show log in the WiFi tether app it says file dies not exist. I haven't been able to get tethering to start... Help or any ideas ??
Screen still flickers in 20130113. Any suggestions or fixes for this?
Have you tried using the built-in tethering? It works great for me.
Yes and although it connects, I still don't get internet connection.anything build.prop or system wise I need to alter?? I remember with the Samsung admire I use to change a line under build. prop from " true to false "...
All I did was set it to be open, no passwords. Hmm..
Is your iccid unknown ??
Is this rom running smooth yet? Dose it still have bugs that are noticeable?
Overclocking on cm 20130115 is pretty smooth
Where can i get the Gapps for this rom? 4.2
