still having probs with my 4g even after the latest update on post #48 but im gonna try to wipe again.
When you flash cm10 flash gapps once that's done wipe cache and dalvik cache again then reboot.![]()
roger that also can u verify which zip did u use since op isnt updating his original thread ive assumed his post #48 was the latest one to work?When you flash cm10 flash gapps once that's done wipe cache and dalvik cache again then reboot.![]()
my 4g isnt working now not even on stock recovery i keep getting 3g..... what am i doing wrong??
how do i check that? and how would i be able to tell if its right or wrong?Is ur iccid/sim right?
still having probs with my 4g even after the latest update on post #48 but im gonna try to wipe again. gonna try to retsore back to old recovery then factory reset then flash cm10
The link that PG posted is updated with latest builds. I think rom manager does too.
I don't know if it made a difference but I wiped factory, cache, dalvik and system before flashing. 4g works for me.
So you trying right now too?
Glad y'all are slowly getting cm10 working. I actually sent an email to the devs at AOKP to see if they would have a release for the metro s3 fit y'all. I'll let y'all know if I get a reply. I know they will be busy with 4.2.
Yes I'm using it I'm really digging cm10 I have no lags wat so ever running smooth, I don't know y some of you are having problem, but I could saw battery life kinda sucks but overall its running good even Google now.
Good afternoon everyone, can someone please tell me how to get/ access Google Now???Yes I'm using it I'm really digging cm10 I have no lags wat so ever running smooth, I don't know y some of you are having problem, but I could saw battery life kinda sucks but overall its running good even Google now.
Good afternoon everyone, can someone please tell me how to get/ access Google Now???![]()
Search is Google now
Long pressing the home button should bring it up too. If cm left it implemented.
I like this rom but two problems. The scrolling isn't as smooth as ics and it makes my browser buggy. The browser settings would stick sometimes but not others. I'm using boat browser btw. Also I can't seem to find where to put percentage next to battery icon but that's probably my fault. Everything else is great keep up the good work.![]()
yup and ClockworkMod ROM Manager - ROMs)When nightlys are available, do we just wipe cache and dalvik, and flash over this?
yea that a bug thats been there for awhile now. I use djdarkknights darkjelly theme and it fixes that issueThis rom is really nice....only problems I see so far are, mms not working and in message settings black theme isn't working, other than that, great rom and job well done!:thumbup::beer:
