If you made the backup you were suppose to make like I said in the instructions then do the following...
Once it's done you'll have the stock kernel from the backup you made.
- Go into recovery and select (backup and restore)
- Then select (advanced restore from /sdcard or /external_sd) depending on location you chose for your backup.
- Now select your backup and choose to restore boot.
Judging from your 2 questions in this thread you seem very new to all this phone modding. Please don't flash any of these mods until you've read enough to know what you're doing to your phone.
I have TWRP recovery version 3. In Backup, should I get backup of "boot" ? Because I don't see "Kernel".
And what's the benefit of flashin this kernel ?
Thank you
Would you please update this ROM to Kitkat? With the same apps, but without lag or bug. I really love your work.
I wish the default setting background for this rom was a dark image, not white.
Also you can use Xplore file explorer, it's way better with lots of feature.
Thank you so much
My highest is 59xx, I average about 56xx and on stock I average 51xx. I'm always in a comfortable 65-70 degrees room temp though.
You shouldn't be using the 1.6ghz kernel on 12b firmware since it's for 10i firmware. It's been reported that firmware 10i kernel has issues on 12b firmware. That's why I have a kernel up for each firmware.
Thanks for this kernal, its the second time I've installed it. This time I'm wondering if its possible to set the CPU to 1604? I would believe it would be fine. Does the kernal have to be edited, or can I edit SetCPU to make this happen? If anyone can help me with I'd appreciate it.
Does this work on other ROMs or just xperion and stock I have hroarks13 kitkat beta
Any difference between Lite and the release of the kernel before latest?Kernel Updated
I made an installer that lets you pick between 2 kernels:
Freedom Lite features:
- Freedom Lite
- Freedom Overclocked
Freedom Overclocked features:
- Unsecured
- Loki'd
- Frandom built in for increased speed - details
- Android TRIM Support - details
- Conservative governor
- SmartassV2 governor
- Intellidemand governor
- Superbad governor
- Init.D support - details
- All the features of Freedom Lite
- 1.404 ghz CPU overclock
- 1.3 ghz L2 cache boost clock - details
Just flash the zip and during the flash you can choose which kernel to install.
NOTE:
Freedom Lite is for those that don't like to overclock or have phones that don't run well with overclock.
Screenshots:
Still doesn't work on KK, right?
can you use this kernel on different roms??
found one by pressypie, thanksHey guys, i don't know how to go into recovery to flash the freedom kernel..any help would hep. (rooted stock lg optimus f6 ms500)
Thanks Game Theory for the freedom kernel....works great and really really appreciate itYou can flash it on any firmware 12b rom.
