GameTheory, can you do me a favor and run Smartbench 2012, and tell me your score? I get around 3100 consistently. On the other hand, my Quadrant scores are wildly inconsistent. I've gotten from 4500 to 5500. Most of my runs are probably around the 4800 range. Just wondering if maybe there's just something up Quadrant specifically and everything else is fine. Thought maybe I had the same problem as PWVR4TT, but I do get the trim log.
I have an LG Optimus F6 (not MetroPCS) and flashed it with your Xperion rom and Freedom kernal.
Okay, I forgot to make a backup before I flashed the kernel. I did make a backup right before I installed the Xperion rom though while it had the original T-mobile 10h firmware. Would restoring it with that backup also restore the original kernel? (sorry, I'm new to this)
Hey GameTheory,
Since hroark13 fixed up the 505 kitkat ROM and from what I read he gave you permission to modify it... Will you update the Freedom kernel with the 505 source? No rush or anything just want to know if that is in your plans. Thanks a ton for your hard work.![]()
I had no plans to modify or work on his rom. To be honest I like to do my own thing and roll solo to avoid any clash. Not sure what I'm gonna do atm. Would like to wait for HK cm11 to be ready or lg to release kk for usa.
No prob, Thanks
off topic but... I am taking Coursera online course then found this ^_^;;
i dont know if you are already aware but here it is,
When There's Freedom, There's Potential...
Freedom Kernel
Built from F6 kernel source code.
Overclock kernel for Metro PCS Optimus F6 MS500
Added Features:
** Note **
- Unsecured
- Loki'd
- 1.404 ghz CPU overclock
- 1.3 ghz L2 cache boost clock - details
- Frandom built in for increased speed - details
- Android TRIM Support - details
- Conservative governor
- SmartassV2 governor
- Intellidemand governor
- Superbad governor
- Init.D support - details
Run your benchmarks when your phone is "not" plugged in to power or usb. This phone has a safety feature that lowers the cpu clock while charging.
Details & Kernel Download
Changelog in second post.
How to setup Link2SD
If you like my work and want to show some appreciation, please click the thanks button.
Enjoy!![]()
That I understand, I just need to know what governor to use and any other settings that might need to be tweaked to achieve the fastest speeds if possible. Like the I/O scheduler.
I have a overclocking program on here, but I have 0 understanding of the purpose of the governors or I/O here. I want to learn though.
