root and recovery are posted in the threads, look for it there, rom...the kitkat version has some bugs but there trying to fix it, so be patience for a bit until we hear more from the developersHello, I am new to this site and new to installing custom roms, so any help is appreciated.
First can anyone provide me with root and custom recovery?
Also, what is the latest/ best custom rom for are devices. Lg optimus f6 ms500
thats cool and all, but what i booted into wasnt fastboot, on screen it said Download Mode, now iam gonna work on figuring this out, could be used as an unbrick method for sure
Could this/they be similar to Samsung's odin mode? Maybe that's how LG support tool does kdz? LoopyD wants to hack the bootloader, maybe he can see what secrets the bootloader holds? UUDDLRLRBA...Well, i just discovered a new mode on the f6 bootloader.
Emergency Mode..
My mindset is different. I get thrills from making the device do things either it's not designed to do or it's designed to prevent me, the owner, from doing. Nexus devices are great and well-supported, but the hackability provided by Google also makes it less of a challenge. The F6 is cheaper and more limited, but can LG really stop you?Stupid LG.... Good luck to you? Morningcall, or whatever it said when you soft bricked a 770? I really had a soft spot for LG phones until they started locking them up. Yeah Loki and 2ndinit were great for these phones but it just got to the point where it would take almost a day on ADB flashing shtuff and unbricking to get a typical LG rooted, flashed with a ROM and configured just right
My N5 has proven to be well worth the ridiculous amount I paid for it. Unlocked and running CM12 in 5 min flat, and almost impossible to brick. Would be nice if all budget MPCS LGs were like that. I love the physical F6 look and feel, it's just empty inside. I'd have easily sacrificed the QR and NFC for more storage anyday. But oh well....
I remember that download mode from my old Connect MS840. From powered off, battery out state, had to press and hold both vol+ and vol- keys simultaneously while plugged into USB. Insert battery, bang. Download mode. That was the only way to restore your firmware using the online LG updater tool if a brick happened. That was, until the KDZ flasher surfaced, making it much easier.
KDZ flasher would also allow you to manually flash MS840V (VoLTE) firmware to a standard MS840 (online updater wouldn't allow that), which was nice since VV4 firmware was way more stable than ZVA.
You could also flash VS840 and LS840 (LG Lucid, LG Viper, respectively) to the Connect. Scary thing was, it would actually boot up afterwards. Somebody with username of Un1ocked confirmed it with pics lol....
Maybe some mad KDZ science experiment could come out of this?
(Take that with a grain of salt, please, as careless flashing runs a SERIOUS risk of a permanent brick!!) [emoji4]
I remember that download mode from my old MS840. From powered off, battery out state, had to press and hold both vol+ and vol- keys simultaneously while plugged into USB. Insert battery, bang. Download mode. That was the only way to restore your firmware using the online LG updater tool if a brick happened. That was, until the KDZ flasher surfaced, making it much easier.
KDZ flasher would also allow you to flash MS840V (VoLTE) firmware to a standard MS840 (online updater wouldn't allow that), which was nice since VV4 firmware was way more stable than ZVA.
Maybe some mad KDZ science experiment could come out of this? [emoji4]
Hahaha.... This is where I'll leave a differential diagnosis between y'all. I'm not a Linux expert, or even a novice. Just throwing ideas out there*gleefully squeals *![]()
Yes, if I remember correctly from LG Motion forums, pissing the bootloader off would result in a morningcall security error. KDZ flasher would fix this, in most cases. But some of the crew were permabricking their phones trying to work around the BL....So it is possible to reflash if you corrupt the bootloader. Good to know.
I gess this sounds like its DL mode the difference its the this is built under other phone criteria. And seems the lg definitely filter in their stuff some way how.Well, i just discovered a new mode on the f6 bootloader.
Emergency Mode..
on screen screen it says ***********************************
* Emergency mode!
* Emergency mode!
* Good luck to you!
Could this be annother unbrick method ?
to boot into emergency mode, power off the phone
hold vol+, power, while you do that, plug in the usb cable to the phone, immedietly it will boot into emergency mode
Like u said before ... It would take someone to sacrifice their ph to find out.So it is possible to reflash if you corrupt the bootloader. Good to know.
