That would b a matter if you fill like upgrading...... Most of the new devices already have root... Dev wise suckss . You can PM @DM for any insights...So, should i get a new phone or keep my hopes up for this one?
For anyone else experiencing rapid battery drain due to Google Play Services, I found a fix by following this guide. I had to follow method 2. I manually created the folder "init.d" and placed the script in it. http://forum.xda-developers.com/google-nexus-5/general/script-google-play-services-battery-t3059585
You are correct... But fella was not specific with his issues... So I just posted original so he can do it manually...That fix is the same fix implemented by kernel with the GSM fix (can use kernel for both version of phone):
http://androidforums.com/threads/me...-f6-lots-of-fixes.880135/page-42#post-6962803
We recommend "fauxclock" . . . to setup ur CPUs
Do you have the SD.back installed? If so... You need to uninstall it then install xpose then install the SD.hackWhy can't I get xposed to install?
https://www.dropbox.com/s/zj6g9m1kz3xgo21/Ss.png?dl=0
Screenshot above
Yes I do. That explains a LOT. Next question, on this latest release I still have extremely low in call volume. Can I tweak to increase this any? I know the op said there was a volume increase in this build, but its not working for me. I did change the mic setting in build.prop to analog from digital to get rid of the call echo.Do you have the SD.back installed? If so... You need to uninstall it then install xpose then install the SD.hack
Which kernal is needed? I have no camera issues. Also, do you have a round about page for build prop tweaks? What gapps is the more reliable? Thanks in advance.Ok... Good...
Well for the vol issues if you did the build.prop tweaks go to the dialer app go to settings and uncheck the voice quality sh*t something like that... Then go to the settings volume steps n set it on 45 or 60 (all) that should fix echo stuff... Another thing make sure you install rom + gapps, reboot... Set up device then reboot in rec then flash kernels ( the camfix and oc...
Is there a newer gapps for this rom, than 060614?
Well you can use any kernel you want if you have a support.cam.phone n not the ov one.... Just so you knw the las oc kernel does not work good with that sd.hack i use it cus i found out that by installing apps that need system biding... N are not sd.movable (swap) support. wWhich kernal is needed? I have no camera issues. Also, do you have a round about page for build prop tweaks? What gapps is the more reliable? Thanks in advance.
Check out my guide I linked to the gapps package I always flash, which is just the playstore. It'll update on its own to the newest version once you start up the phone, sign in to your google account, and then restart the phone.Is there a newer gapps for this rom, than 060614?
Go to system settings go to tethering & Networks go to APN and select your provideris such there a VPN to flash upload download on the carbon ROM Its saying I have no network??? And would have been nice if the last set of instructions I received mentioned kitkats SD hack ughhhhh
