Root [MetroPCS] [ROM][4.4.4]CARBON ROM Kitkat 4.4.4 for LG Optimus F6 [LOTS OF FIXES]
some of the cm11 themes don't work either but i'm fine with the theme i've installed
Some of the cm11 theme would not work with yhe latest rom built. Cus when DM implemented the apps2sd support it broked alignment... So some apps either would not work or data will b broken. (Not able to detect sd card as mounted) the only way that it would work for now its by going back to old built. With new kernels but you would hav2 implements tweaks for rom not to random reboot n vib issues....
So do I just turn vibrations off completely in the old build?
Which kernal should I use with it?
I like this ROM a lot, but I hate the reboots
No issues, well none that I've seen.
Everything works, except the Bluetooth and some themes.
I was also wondering if it's safe to over clock the ROM without causing issues
Or of there is a compatible kernel available
Ok got you... This its what are you gonna do ...
Go to recovery wipe/factory.reset
Then wipe data/ cache/ dalvik cache
** install lates Rev2 Rom and gaaps
Reboot.... Setup ur device
Then reboot into recovery again
Wipe cache and dalvik
*** install this kernel http://androidforums.com/index.php?posts/6957959
** Superhcharged-A1b2.intelliplug-1.8ghz.zip **
Reboot. You should be good to go and overclock u can use whatever cpu app that you like. We recommend "fauxclock" or "PerformanceControl" you can use 3c.Tools ( Android Tuner) to setup ur CPUs
"Notice" with new Rom some apps would not upload properly cus binding is broken Thanx to the apps2sd implementation. For any apps installed after the SD.hacks would encounter troubles... The only way to fix that its by either forced.install in root directory like priv-app or apps not on data directory... I recommend that you should take your time and read through the entire threat to understand what its going on. Specially if this is all new to you. So you won't encounter bootloops or softbricks.
Another thing all CPUs app should be paid ones or free apps with the most options allowed. For the best use of performance
Go to the system/etc/snd_soc_msm of the Carbon rom. Delete and replace the snd_soc_msm_Sitar with the one from hroark13's KK port. Just extract the rom and look for the file and replace it. I would upload it, but it won't let me or I would post it here. It's not a normal file format that my pc regonizes obviously. That file makes the sound back to normal although the speaker volume is a little low. Other than that the incall speaker and everything else is fine.
Whenever you have a file that your computer or phone won't let you upload or send via Bluetooth just zip it up and that solves the problem. It also saves bandwidth and guards against file corruption because you usually can't extract a zip that gets corrupted so if it won't extract then you instantly know its a bad upload or download.
Wow I feel stupid. lol I guess there is a first time for everything. Thanks.
So it would be just changing the name of the directory for no reason. No benefit to doing so which is what I figured.
correct... it would b beautiful if we can get rid-off emulated dir. and only have inter/exter dir only plus usb/storage it could be more simple b.cus that fuse stuff it has never really workd
