Root [MetroPCS] [ROM][4.4.4]CARBON ROM Kitkat 4.4.4 for LG Optimus F6 [LOTS OF FIXES]
Hi everyone, I installed Carbon last week and have been loving it so far but my only issue is that people who call me hear an echo of themselves. I've tried several of the methods posted in this topic but none have seemed to work and was hoping maybe someone has any suggestions. Thanks.
In my experience, this happens only when I use the speaker phone.
I'm using the kernel and rom from this guide after I did a reflash yesterday
http://androidforums.com/threads/ho...-ov5693-cam-12b-version-of-this-phone.919755/
Ok.... Now have you done the build.prop editing? If not add this to yours.. Make sure u knw what you are doing. Cus it could get stock in a bootloolp. Make sure you clean up build.prop for any repeated lines.
# System props for audio
persist.audio.fluence.mode=endfire
persist.audio.fluence.speaker=none
persist.audio.vr.enable=false
persist.audio.handset_rx_type=DEFAULT
persist.audio.handset.mic.type=analog
persist.audio.headset.mic.type=analog
persist.audio.dualmic.config=false
persist.audio.lowlatency.rec=false
persist.audio.voice.clarity=none
ro.config.vc_call_vol_steps=60
ro.config.vc_call_vol_default=60
# System prop to select audio resampler quality
af.resampler.quality=255
persist.af.resampler.quality=255
persist.audio.samplerate=48000
persist.af.resample=52000
ro.audio.pcm.samplerate=44100
persist.dev.pm.dyn_samplingrate=1
# System prop to select MPQAudioPlayer by default on mpq8064
#mpq.audio.decode=true
Go to dial settins and unchecked (disable) noise suppression
Reboot into recovery
Wipe cache.. Reboot.
Just one question about editing the build prop, can I just drop those in at the end of prop or do they need to be in a certain section?
U can put them wherever.. It longest u leave an empty line @ the end... And like i said make sure you dont have duplicated ones... I could give u my whole build.prop but it has fingerprints settings for newest built. Not for the oldest one.
I didn't find an option for noise suppression in my call settings but I modified my build prop and people are still saying theres an echo :\
Did you wiped cache n dalvik cache Go to dial app click on menu /settings
Hello again. I was trying to theme this phone with those cm11 themes but I ran into a problem, anytime I try to install a theme with the cm theme app or play store, the theme installs successfully from the store then fails on my phone. However, carbon specific themes do work just cm themes fail. How do I fix this?
I still am using the latest kernel and ROM.
are all the original steps still needed as before this revision?
sitar and build replacement...
vibe off....
crt off...
bump up the low CPU setting...
and kernel...
just wondering....
I still use my f6 as a pandora server for my house stereo...
I really wish I could flash this on my ZMAX....
but, I've bricked it enough times doing things "correctly"...lol..
vibe off....
crt off...
and kernel...
just wondering....
If you have old 10e or i firmware No... If you are trying to use the camera support. 12b n u want vib u need to do it yes but u should use the cm11_4.4.4 camera.vibs.blusleep guide
Hey man I want to give you props for fixing the random reboots. This ROM is awesome. Great work and hope to see what you have in mind for the next update. The only issue I have is with the bluetooth, it doesn't connect and keeps turning on and off.
Which kernel are you in.?
