Masterchief87
Android Expert
Just go to the regular lg optimus f6 section instead of the root section. Its a sticky thread so it will be near the top of the list of threads.
Hroark13 built twrp. The lte2 recovery you are talking about is CWM based recovery so either you are using twrp and confusing it with CWM or maybe the other way around. Either way you are mistaken and need to do some fact checking. Also, if you are using twrp 2.8.0.0 try twrp 2.6.3.0 because it is more stable.Lol, wow all that talk and now lte2 recovery wants to uncheck the system and or data boxes on me loooooooong after I flash ROM on this F6. Funny every once in a while before flashing Carbon or xperion not that the ROMs themselves matter but ya after formatting data inside Hroark13s lte2 TWRP every other reboot the boxes randomly uncheck themselves preventing data/system mounting..Sooooo irritating! Ughhhh. So I'm back up and running flashed Carbon ROM for 3rd time get halfway through setup and I say......reboot to mount exposed mod or somthin then my phone gets stuck on boot logo so I'm gonna try only rebooting to recovery first then reboot system as I have to check system and or data boxes to make sure she mounts. Funny never did this before. Wish that genius Hroark would update lte2 juuuuuuus a tad for us a?
Lol where is hroark13 at I sure don't see him. He stopped working on the f6 nearly a year ago yet it looks like you are trying to speak to him directly. How exactly are you booting into recovery? If you turn the phone off and then boot into recovery by button combo it will zero out the data partition before you get into twrp. Then you have to select wipe then format data and type yes to confirm then after you format data you have to select the reboot option then select recovery and when you reboot back into twrp you will then be able to mount data. If you want to avoid all this hassle then always boot into recovery with an app or by advanced reboot in the power menu.Ya Hroark I'm on 2.6.3.0 lte2 recovery TWRP. Trevor Phillips root and recovery guide is where I found you're nice work really nice Loki job, however if I don't boot into recovery first to make sure boxes are checked she's more than likely only gonna give up a boot logo screen. Just double checked by booting into recovery system and data were not checked again so I checked em and rebooted. Owell if that's the workaround for me from now on so be it. I meant you no disrespect Hroark you're awesome bro. Shit happens I guess and this is what's happening. But no its nor CWM its 2.6.3.0 touch based TWRP been using it for bout a year just started this last night idk man
thanks so muchlike when you set it to 30 seconds till the screen goes off well when it dus that I press the power button to wake up the phone to the lock screen but it stays all black nd the bottom navigation keys stay light up and then it reboots on its own I Juss wanted to know if it happened to others or did I not do sumthing right?
