If you want more battery life, I'd pay attention to screen brightness and background apps. Also startup apps can cause battery drain. The bootmanager xposed module should help with that. You can also try amplify xposed module to help with wakelocks. Otherwise I'd use xperion ROM + freedom kernel if you want the most battery life. It's more efficient than this. This rom with the overclock kernel is geared more towards speed and smoothness since this phone's battery is already huge for it's low power consumption by default.I need help. I love carbon rom but i need to know what i can do to make it better im going to probably do the sd card hack but sometimes i would get low signal is there anyway i can boost it and also i dont like how the led runs when you get a notification charging ect. How can i limit that And how can i boost battery life i use my phone alot and i really love 4.4.4 and this is a really good rom its stable
Upvote
0
