Settings-tethering & network-apn = (on system menu)Edit: Nevermind, Christ I'm a dunce.
Okay guys where are the APN settings hiding, I want to double check that they are the right ones.
That means you downloaded the wrong apk (wrong version) its one of each version =jb,kk,ics,LL or just google "CM Apollo.Mod"Tried to start a thread on Appolo player but no luck, So since I'm trying to get Appolo setup on carbon ROM 4,4,4, figured this next best thing sorry AF. My ordeal is I can see the Apollo folder in which I downloaded in my filemanager but when I click on it long press etc. Its says there's a problem parcing the package? Never ran into this typebof ordeal before having a hardtime finding info on what needs to be done. Weird.
Sending you a pm...check your inbox in a minute...I so promise to get this his forum stuff down I knw its simple. & I don't mean to be an idiot but how the hell do u start a thread if What U type in search box isn't available for topic. Ahhhh I gotta be mission the point here sorry folks
Well not all themes are gonna wrk good... If you gonna dl a theme from playstore you need to "READ" descriptions... Of DPI n they have to be for CM11 onlySo obviously its ok to go with any of the cyanogemod themes and what not that are offered with Carbon ROM correct sorry just wanna be 1OO% on this. I mean if its offered up to U within the Rom it must be ok to go with I mean again I'm just asking because it is CyanogenMod themes after all.
Damn glad I asked. I wondered about what all cyanogen stuff worked with this rom
You can install CM themes its no problem with that...Wow why would the devs create a link inside a ROM that leads to cyanogen themes that aren't all compatible ?
