You're not suppose to flash the kitkat xperience. Read what it says next to the link.![]()
Hey thank you for all that you have done for all of us.
Is there a Custom ROM that has the "sdcard0" swapted or already cooked into it so we noobs don't have to hoppity hoops applying scripts to swap (tick) the tiny storage into the real "sdcard" storage?
This guuuuuuuuuuuyyyyyeeeeee lol
Sorry, but you have to look at it like this.
An SD card can vary in different sizes depending on the owner and their needs for storing media limited by their financial lifestyle, haha which is me lol. And, also, the micro SD card has to be formated by the user depending on what they want as extra space for their SD and their media, and maybe even their ram.
Grrrroovy...OK will stated!If you would have said maybe, is their a ROM which maybe has an application or requests the user before installation which can help a newbie in an intuitive way to mount scripts??? Set up n ext partition by asking how much he would want for the ext and fat partitions... That would have been more sound and should be open up for discussion to enhance users experience with unlocking the power of root and roms
I have Xposed so I downloaded and applied the ex-themer mod. It will change the wifi icon but none of the themer mods I tried will change the data/signal bars icons. I wonder if it is something to do with the Xperion rom i'm on. Do you have any thoughts on this GameTheory?
There are mods that change the data bars. My xposed is messed up, but i'll find out which one I used to change it.
Well I ended up just decompiling the system apk and making my own custom icons which is a lot of work but it got the job done.
Edit: added screenshots
Does this Rom fix the storage issue I constantly get about insufficient amount of memory?
That's not something any rom is going to fix. This phone has a small internal storage. You can try link2sd or any other fix, just look around the forum.
Does it matter if I have version 10 or 12?
Because I'm pretty sure I have 12...
is this still alive? also how is this rom? any vids on this rom?
- Yes
- Up to you to decide if you install it.
- There's screenshots when you click the download link in the first post.
Hey Game gonna add anymore things to this rom?? Also you know the CM11 notification bar/ status bar is there any way to get that on your rom? Cause your Rom is amazing hope for your reply ! Cheers Mate!
no idea how to change the battery icon then? just a question even if i have to recompile framework-res.apk
could we?
