There are 2 ways you can do it. One way is to copy LgSystemUI.apk and LgSystemUI.odex from /system/app in the stock rom to your SD card then put it back after you install Xperion. Note that this will also change the status bar from black to grey and change the icons from white to blue and will change the look of the notification drawer also.Game Theory want to install this ROM but I have a doubt. Is it you can change the battery icon? because I do not like the round. ahhh, I am using the translator as no English![]()
You would use gravity box to make the status bar transparent. Set the transparency to 100% for launcher and 50% for lock screen.ahh another question. Does the status bar is transparent or box sets with gravity ?. Well, I hope and continue to improve this great ROM, but I would like cyanogenmod 12 for this phone![]()
Hello again, I just install the Rom but I have a problem. because I have so much space occupied if just and installed as 6 applications?![]()
but I had many more applications and I had plenty of space and now just and installed as 6 and now I almost no space. There is something wrong
look what I say
k what I say
This phone has very little internal storage space, there's no rom that can fix that. If you want to add more storage space go to the sd hack thread HERE and ask there if you need help installing it.
Hey whats up GT i was wondering, is it possible to unbrick on this rom?
Nah I don't use any sd hacks, but you can get good suggestions in that thread.
I don't know, I've always just used the sd card hack to increase the internal memory, completely avoiding any incompatibility with apps.I use and like LINK2SDPlus. The question is why do others decide not to use it?
Hey guys! So my gf has a metro pcs optimus f6. Now to root it I just use towelroot? And how do I get a custom recovery? Does software version matter or anything? Sorry if I'm asking in the wrong place but any help is appreciated!
