obed9armah
I don't really know which one to choose but any that would work fine with the xperion Rom will be fine. Apps I am trying to install from the stock: music.apk, Optimus theme.apk, videowiz.apk, and music widget.
OK then I'll use deodexed versions since its a deodexed ROM.Newest
I have no idea about videowiz but here's a zip to install the stock music player & widget, and optimus theme.I don't really know which one to choose but any that would work fine with the xperion Rom will be fine. Apps I am trying to install from the stock: music.apk, Optimus theme.apk, videowiz.apk, and music widget.
What does increasing swap to 80 do ?
Thanxs GT sorry if that bothered u I appreciate it tho
For the sake of this explanation "linux = android" and "hard drive = android's internal memory".
In linux when RAM(random access memory) is running low it uses allocated space on the hard drive called Swap to supplement the ram. Keep in mind that ram is faster than swap on the hard drive. By increasing the swappiness value you're making it use the swap space more agressively and rely less on ram. By reducing swappiness(not recommended unless you have lots of ram) it will use less swap and rely more on ram.
That was a brief explanation. For more in depth info do a google search and you'll find a wealth of info on this topic.
I am having a 16GB ext SD, can someone please give me the steps in creating the above process?you have 2 options you can make a swap file using an app like Swapper2 and use that or you can partition your sdcard to have a swap partition, then set up swapper2 to use the swap partition instead of file. BTW if you use partition make sure to select the right partition or device otherwise you could brick your phone, and this is a brick where you need to reflash every single partition of the phone anew.
