Masterchief87
Android Expert
Are you rebooting to recovery with an app or turning the phone off and pressing power+volume down? If you are using the button combo to get into recovery then that could be the problem.
The first time into Recovery I used the app. It was after my attempt to install the ROM successfully failed that I had to use the button combo. You can't use the app if you can't boot? I could use the KDZ as I described above one more time to make sure I did not miss anything?Are you rebooting to recovery with an app or turning the phone off and pressing power+volume down? If you are using the button combo to get into recovery then that could be the problem.
[I just woke up this morning to a blank screen on my phone even though it was powered up. The blank screen did not respond to any key or screen touch. I held the power button down to power it down and then held it in to power it up]
I can't get past the Xperion boot logo. I have tried removing the battery and putting back in again. "Xperion_ROM_f6_12b_6-5-2014.zip" is the version of the ROM I have been using. I am also using Links2SD. And, I have a 32GB Micro SD Card installed. What should I try first?
EDIT: I tried removing the SD card and was able to get the phone to boot up. But, because I have been using Link2SD [using the SD card for all kinds of app storage, etc.], I have all kinds of issues. Google Play Services, error message, pops up, "App is not installed" error messages, [for example]. When I put the SD card back in, the phone can't get past the boot logo. NOTE: I put the SD card in my card reader on my laptop and was able to access it with no issues. Does this mean that the SD card is OK? And, that something else is to blame in combination with the SD Card?
EDIT: I used this, http://androidforums.com/threads/metropcs-guide-using-kdz-to-get-back-to-ms50010i-firmware.843494/, to get back to the original firmware. Next, I held the vol -/+ buttons and pressed the power button to erase. I'm not sure if I did this in the right order? Next, I installed the SD card. The phone is able to power up/down with this installed. I'm not sure what happened in the beginning of this. But, everything seems to be OK now. I am ready to root, install TWRP, and flash the latest ROM?
My guess is your sd-ext partition had a file system error and got corrupted somehow. The kernel was unable to mount the partition. If so, my advice at this point would have been to run fsck to fix the file system, either with my fsck zip or by command line in TWRP. If you had USB debugging enabled, you could boot into TWRP without triggering factory reset by using ADB (adb reboot recovery).I can't get past the Xperion boot logo.
Unable to mount '/data'
So your /data partition was most likely zeroed out by using the button combo. You need to format it to fix it. I believe the stock rom would automatically format a blank /data partition during boot. GameTheory can correct me if I am wrong, but I think Xperion puts stuff in /data, so that means flashing would fail without a mountable /data partition.The first time into Recovery I used the app. It was after my attempt to install the ROM successfully failed that I had to use the button combo.
I don't think TWRP's wipe data function actually formats the partition because it tries to preserve contents in the emulated SD, which is at /data/media. So like Masterchief87 said, you need to actually format the partition used for the internal /data to proceed. As for the sd-ext problem, if you don't need to recover any data from it, format that too using the correct file system type. Otherwise, you can see whether it's recoverable by using fsck.And, if it's internal, TWRP should be able to format this as part of the Wipe/Factory Reset?
What should be the title of this new thread? We have to be sure of what we are discussing? i.e. Why 'sd-ext'? If we are talking about the 2nd partition of the external SD card - Why should this matter at this stage when we are installing a ROM?
It's not a rom problem since everyone else is able to install it just fine. Your problem was caused by link2sd. You should consider switching to Warranty Voider's SD hack which is more reliable. Here's the link...
http://androidforums.com/threads/sd-hack-for-storage-expansion.908126/
Sd-ext is the recovery's term for 2nd partition of the SD. I used that term so that the recovery messages would make sense. Should have mentioned that at least. Sorry about the confusion.What should be the title of this new thread? We have to be sure of what we are discussing? i.e. Why 'sd-ext'? If we are talking about the 2nd partition of the external SD card - Why should this matter at this stage when we are installing a ROM?
You would have to replace the lock screen and dialer apps from xperion with the ones from stock. Those apps, however, are two of the biggest differences between xperion and pure stock.Just wondering if it's possible to change the lockscreen picture to something different from the homescreen background. Everything I've tried (even XBlast) fails to let me change the lockscreen pic. If it's not possible, no biggie. But it would be nice if anyone knows how.
Thanks,
Edit: Oh yeah, also, is there a way to theme the dialer, or change the colors? The white on black isn't the most appealing to me, at least.
There are 10 steps. Step 5 is where you use "Xperion_ROM_f6_12b_5-2-2014.zip "? Step 7 is where you use "Xsetup_v3.zip"? [Step 10 is optional] If you are going through these steps for the first time, you are done?
EDIT: I am waiting on some further instruction on CWM - http://androidforums.com/metropcs-o...covery-loki-cwm-v6-0-4-6-a-2.html#post6550892 I am trying to verify if "F6Utilities2.apk", once installed, downloads the CWM as well as installing it?
Thanks for this "What do."De-odexing is useless to the end user and makes the rom slower. The only advantage to de-odexing is for the developer to be able to easily modify an apk. A zipalingned rom with its odex files can be much faster and smoother than a de-odexed rom. It's always been this way.
What do
Hello. Thank you very much for Xperion Rom and for all you do.
I bought my Metro PCS LG MS500 last August. I'm running Xperion Rom 8-19-2014. I installed using the instructions at
androidcreations.weebly.com/xperion-rom-f6-ms500
That is, only 5 steps mentioned. Am I missing anything?
Saw that and I just wanted to ask- would there be anything preventing someone from pulling the xperion dialer and lock apps, skinning them, and flashing that back? Not sure what the current deal is with apps being signed, etc.You would have to replace the lock screen and dialer apps from xperion with the ones from stock. Those apps, however, are two of the biggest differences between xperion and pure stock.
-edit- you could also flash the old version of xperion if GT still has it on his website. That one has the LG lock screen from the stock Rom.
