MizzouBrent
Android Expert
Are you on all the most recent radio, pri and nv updates?
Any reason why you didn't format through recovery? Just curious, I like to do as much as possible within the phone.
It shouldn't matter one way or another..
Um...maybe??? Not sure. I'll tell you this. I rooted for the first time about a year ago, used a stock rooted Froyo and Gingerbread ROMs and then my first custom ROM was MikG 2.56 back in about August/September 2011 and been on that up until 3/3, last week. If the radios, pri and nv are updated WITH THE ROMs then I AM updated. If it something that I would have done separately then no, have never updated them.
How do I check if I am up to date?? Also, you're the VERY FIRST to ask about the radio, pri and nv...and there was no mention of maybe or likely needing to update with the release of MikG 3.XX...so I was wondering your thoughts with the radio and/or pri issues?? I'm up for trying ANYTHING but would also like to understand the thinking behind the suggestions....
THANKS!!
Here is supposed to be a link to latest stock rom.
[ROM] 4.67 - Rooted - Optimized - Sharing means caring - xda-developers
How about backing up and wiping appropriately and flash it?
You are still on old radios too, huh? Don't think that would be a problem.
There is a version of previous stock you might try too.
Let us know. Hang in there.
Actually - upgrading the radios, and then updating PRL & Profile might also help. Sometimes the old radios don't work well with the newer drivers, and can cause instability. At this point, it definitely couldn't hurt to try.
just something to keep in mind with everyone having random reboots.
there are certain ICS roms that i have loaded on my evo that keep rebooting for no reason. Well just today i think i got it narrowed down to kernel voltages. even with or without overclocking it, i would get reboots. even after a feresh install and not doing anything.
well today, i used vipermod and set all voltages to -25mv and it hasnt rebooted once since.
moral of the story? try to undervolt your phones, and see if it stabilizes the issues as it did for me. certain phones just simply dont like certain kernels.
we were talking about it over here too in the very disgruntled thread.
I thought of the radios as a variable but didn't think they would be a problem. The Captain says they could be, so, it is definitely worth a shot.
I admire the tenacity in which you are trying to tackle this issue.
As far as radios go, I'm not sure if that will affect anything or not, but they are updated seperately so if you don't remember doing it chances are you haven't.
As I suspected, tommys classic EVO gave you no problems.
These reboots happen on a few of my fakilys evos running mikg, and neither of them have a partitioned card
o.k. here is another new and weird issue from the reboots
I pulled my phone out of my pocket and it was on the go launcer screen. I hit the home button to go back to the sense screen and it wasn't there. I have no sense apps or widgets. I keep hitting the home button and it stays on the go launcher.
pulled battery and rebooted still no sense version. do I have to reinstall mikg or just go to a new ROM. again I need a sense ROM.
What I think you did was to somehow choose your Go Launcher as your DEFAULT launcher app when you hit the home screen.
Go to the Market (Google Play) and download this app:
https://play.google.com/store/apps/details?id=com.teslacoilsw.homesmack
When you launch this app, you'll be able to choose between the Sense launcher and the Go Launcher AND redefine your default setting for the home key.
I think that is what you did and the app will help...
I appreciate the compliment. But tenacity?? Doesn't everyone have a week and 12+ hours a day to figure this out??![]()
have you tried and update your radios?
Yes to where to find radios, it is listed as baseband number.Nope...but headed there after my current little test
Questions...
First where do I find out the versions of what I have?? I don't have my phone on me as I type...is it Home —> Menu —> Settings —> About phone??
Also, I've never flashed a radio or updated PRI or Wimax or anything...do I just follow this guide here:
Radio Update - 1/21/2012 - 2.15.00.12.19
And if I have a problem do I just flash back?? Where do I get "my old ones" back to reinstall and how do I do so??
Questions...
I'd flash the combo thats at the bottom, radio, wimay, PRI and NV all together. Make sure you nandroid before and you have almost a full charge, lots 'o battery. While flashing do not under any circumstances pull the battery, possible trip to brick city my friend.
Awesome man. That fixed it. Don't know how I did it but that worked.
Now I am going to try that under volt and see if MikG 3.1 still reboots.
please, PLEASE let us know if the undervolt helps your/our/my reboot issue!! I'm currently running MikG 3.11 for the LONGEST period of time I have in the past week WITHOUT a reboot but not quite confident enough to disclose what I'm doing. Actually I'm not quite sure whattheHELL I'm doing so THAT is why I'm disclosing it!!
I gotta collect my thoughts and really see if I'm in better shape than before. Also a couple other lose ends I'm not so sure I can make conclusions about...yet. We'll see what's up tomorrow.Scudder, I may be way off but I'm just trying to help.
After you've set stuff back up and it reboots does it continually do it like every hour or something? It's not the reboot that goes with app being moved to the SD via A2sd?
Could it be an EVO version specific problem? Wasn't there some other app or rom or somethingthat didn't like some phone version?
