Anyone else having an issue launching the Dialer after applying the circle mod?
When I try to open the Dialer the screen blinks, and it looks like I lose cell and data signal for a second.
Going back to the original framework or clearing the dialer data did not help.
nope, I just tested out mine and it works fine....
It looks like it might not break until I modify the screen density using jrummy's overclock app.
Yup looks like it breaks after I run a build.properties mod.
I am getting closer, just missing that Gingerbread Blue circle battery.![]()
No worries, beggers can't be choosers.I'm working on it now... should have PNGs to you shortly. I got back in later than I thought so I had to wait until now to start on them. Will keep you posted.
How hard was it to do the other graphics? I was thinking of trying an all orange theme (instead of the default green) but I didn't want to get in over my head.
And glad you like it! I'm actually going to be working on the 3G and Wireless icons next.
OK, here are links to revised green icons and all new blue icons. Fab, feel free to update the toolbox with both if you want to offer both:
Blue Icon Pack (Battery Status): http://dl.dropbox.com/u/1842772/blue_icons.zip
Green Icon Pack (Battery Status): http://dl.dropbox.com/u/1842772/green_icons.zip
While trying to flash the the green icons zip, clockwork freezes up. and i have to battery pull to recover.
Second one for those who would like it.
100%-80% is Blue
70%-60% is Green
50%-40% is Yellow
30%-20% is Orange
15%-0% is Red
You can get it HERE
After downloading the file what should i do extract it to get the different color icons and then i can install the one i want ? . Do the other colors look like the green ? , the style of the green is very nice .
Does this install through boot strap recovery and then just install the zip or how?
