Root [MOD] Apex V1.4 Circle Battery
no, you install the zip in clockwork. the colors of the battery symbol change depending on how much battery percentage you have left... just like the breakdown describes. starts off blue with a full battery then goes to green yellow orange and red as your battery goes down
Oh ! ok , i already installed it from the Apex toolbox but when i saw this thread i thought you had made the icons in different colors guess i didn't look properly to see that each color had a percentage amount beside it .Thanks man it's very nice .
there are two the one in apex toolbox and the one that changes colors several times. post pictures can be seen in the first post and you can see how they look different.
I sent the second one I made to fab. it may be in the next toolbox update, it may not. thats up to him
and no you dont have to mount the system for these
Ok thanks man
I am working on porting Gingerbread Red over from Liberty:
Actually pretty much have it done.
bhmstuff, if you would be so kind to work your magic and create a some circle pngs matching the attached red, that would be awesome.
Here are the blue icons (for wireless) I was telling you about. I also tried to do a swap color on the green in the lock icon to the blue you asked for. Let me know if it looks OK... it was a little tricky.
http://dl.dropbox.com/u/1842772/addl_blue_stuff.zip
I'll need some time to get to the red ones.
The slider looks great (too bad I can't get it to work right after I replace it). So I wouldn't spend anytime on the red slider at this point.
I like the new Wifi pngs, but I think the color is a little off, they seem to be a little dark???
You can either update them or just abandom them, whatever you want to do.
Great work though.
I am running the Black, White, Chrome theme for 1.4 and it already has the circle battery meter, but I like the color scheme you have on your second posted meter. Will your meter work with the Black, White, Chrome theme?
No. Not straight as they are. These replace the entire framework-res.apk which is some of your theme comes from.
BUT... you could use 7zip to pull the images and ninjamorph to replace them in your theme on your phone.
So, I can't just install this one and it overwrite the current one in the BWC? Will have to save this project for another day then :rolleyes:
I like the multi color battery circle, nice work! Any chance the 3G and wireless signal meter can be white like the Revolution theme was on APEX 1.3? I'm not a big fan of the way those icons look.
does anyone have the zip for a battery icon like the first one on the post but in a matching color
thanks in advance
thanks in advance
Yeah one is posted in here a few threads down from the first post ( im on the mobile app so I dont have the link but its there)
Apex tool box is in the terminal emulator ... go into it and type
su (enter key)
Apextoolbox (enter key)
I changed the green of the battery to match the green of the signal, wi-fi, etc. If anyone is interested, you can get it here.
Thanks to the OP for the file in the first place :D
It's the link in the word "here" above. ;) And yes, the color matches perfectly.
thanks in advance
that's a different color green.
