LexusBrian400
UPDATED 9/4
9/8 Update - These are available through Rom Manager now
Ok, so I went through the build.prop tonight and tried a few things out. I figured I'd just post all of my edits for you guys to try and use also. Here goes...
I am listing the changes one by one w/ descriptions, as well as providing all the mods rolled up into a single build.prop which will be posted at the end of these directions. Enjoy
To make the phone ring faster when dialing out, I changed
ro.telephony.call_ring.delay=3000
to
ro.telephony.call_ring.delay=1000
Now the phone rings pretty much instantly when dialing out.
To enable better scrolling speed through lists, I changed
windowsmgr.max_events_per_sec=55
to
windowsmgr.max_events_per_sec=60
Scrolling through the app drawer and contacts and any lists really is now smoother
Now, to save battery by decreasing the amount of time Wifi looks for an access point, I changed
wifi.supplicant_scan_interval = 60
to
wifi.supplicant_scan_interval = 90
Now wifi will scan once every 1.5 minutes when not around a known location instead of once every minute which will save battery.
I also changed the Dalvik VM heap size from
dalvik.vm.heapsize=30m
to
dalvik.vm.heapsize=32m
I remember doing this on my Eris and I was able to run JIT w/ sense enabled (which was a major hassle at the time) It helps with stability and gives apps more room to run afaik
To change LCD Density (How much is displayed on screen) visit my other build.prop mod page
Here -- Droid Life Forum • View topic - [MOD] LCD Density - DIY! - Droid X
And To fix your 2.2 market to display all apps Go
Here -- Droid Life Forum • View topic - [FIX] - 2.2 Market Issues - Show All Apps
Now for everything listed here all rolled up into one single build.prop, download this
build.prop
Install using any method of your choice
Method 1 - ADB
1. Download
2. Put the build.prop in your android-sdk\tools folder
3. Connect your phone via usb, make sure it shows up with adb devices
4. adb remount (or whichever way u prefer to mount ur system)
5. adb push build.prop /system/build.prop
6. adb reboot
Method 2 - Root Explorer
1. Copy the build.prop to the root of your SD card
2. Long press on build.prop
3. Select "Copy"
4. Navigate to /system
5. Click R/W in the top right corner
6. Paste, and overwrite
7. Reboot
My results
If you do not like or want to use the LCD Density mod, use this build.prop. Everything else is included.
build.prop
UPDATED BUILD.PROP
Ok here are a few updates.
To enable the hard key lights to stay on while the screen is on and not timeout, I changed
ro.mot.buttonlight.timeout=1
to
ro.mot.buttonlight.timeout=0
To make the phone come off of the "black screen" in the middle of, or the end of phone calls when you pull the phone away from your face, I changed
mot.proximity.delay=450
to
mot.proximity.delay=150
The delay is almost no longer NOTICEABLE at all. (It was very annoying to me personally)
*Note - this will not include the lcd density mod, but everything else mentioned on this post included. Thanks guys! Enjoy
UPDATED Build.Prop
Follow me on Twitter
Donations would mean a lot to me right now! Even seeing a dollar is a nice boost of confidence to spread out and do more than build.props! Thank you guys
