CuBz
Android Expert
Many thanks to BIN4RY on XDA
`Many thanks to My_Immortal on XDA for this
For those that do not have Root Explorer and do not want to purchase it, you can download Super Manager FREE from the market!
Bin4ry said:Download latest flashtool here:
NEW X10FlashTool - All in One (15.01.2011) NEW - xda-developers
Extract the Dualtouch.rar from here:
Multiupload.com - upload your files to multiple file hosting sites!
Mirror:
http://dl.dropbox.com/u/17170888/Dualtouch.rar
and copy the "Dualtouch" Folder inside the Firmwares Folder of Flashtool.
After that just flash and reboot =)
If the Rom is capable of Dual-/Multitouch you will have it now.
Regards
Bin4ry
NOTE:
This will just ADD dualtouch feature to your ROM. It will not wipe userdata or something else, see it as an addon =)
My_Immortal on XDA said:So, I installed the latest DT kernel from SE in my X10 using this trick (Thanks Binary!!!).
I am currently on stock SE ROM, 2.0.A.0.504, and I noticed that dual touch was not working on every app, but only on some third-party apps.
So, I did some research and found out how to enable it in every app that supports it!
It is very easy!
FIRST FLASH THE LATEST KERNEL, AS DESCRIBED HERE!
And then...
Step 1 (Optional, according to arkedk, thanks for pointing out!However, I did it on my phone, it doesn't cause any trouble and I haven't personally tested this method without it)
- Using Root Explorer, navigate to /system, press the Mount R/W button, find build.prop, long press on it and select "Open in Text Editor".
- After the last entry, add the following lines:
Code:ro.product.multi_touch_enabled=true ro.product.max_num_touch=2
- Press Menu, then Save and Exit.
- Delete the build.pro.bak that was created (or move it to your sd card, if you want to keep a backup)
Step 2
- Download this file and, using Root Explorer, copy it to /etc/permissions. Then, long press on it, select Permissions and make sure that these options are checked: the whole first column and the first from the second.
- Exit Root Explorer and reboot.
DONE!!!! Try it on Google Maps!
Oh! And consider pressing the "Thank You" button if I made your life a little better! LOL!
