Root Myn's twopointtwo!!!!!!!!
brianvillage5
Sooooo I think I have found a combination I'm happy with, and I would like to see if anyone else has it or has any suggestions that would be better. Of course I have myn's twopointtwo rls5 netarchy toastmod 4.3.4 Cfs no havs, my radio version is 2.15.00.09.01, pri and nv are downgraded to 1.77. And mabye a few other things. Its working for me though I have been playing with some kernals lately the one I have seems to be tthe best one I've used as far as just being cleanly fast and also having the front camera.
cm7 cm7 cm7 cm7 lol oh, and not to be a spelling nazi, but its kernel not kernal :) sorry to nitpick, but its like when people say irregardless lol
Everytime I used a gingerbread rom I just didn't like it, they were fast and everything but for some reason the sense roms with a netarchy kernel were just awesome. I went back to the one straight in warm updater, whatever that one may be. I lost my front camera again, but its a sacrafice I'm willing to make. Because A I don't really use it that much and B I'm getting super good battery life and unmatchable performance.
I'm just looking for some suggestions on my phone or seeing if anyone has he same or different combos as me that work better or worse this is a forum not English 101 people. No periods or commas needed, and use all the Runon sentances you want just like meeeeeee! !!!!!
There are thousands of combinations out there, and not all work the same on different phones. The most important thing to consider here is: Are YOU happy with what you have? It's not a matter of what rom I think is better, it's what works for your preference. ;)
Now kernels are the same as far as what you want to get out of them. If you want performance, get a BFS kernel. If you want better battery with average performance get one with CFS.
Try everything out there! You're on the right track, keep trying everything out and you'll find what is best for YOU. :)
Thanks I am happy with what I have. I'm trying to get my front camera to work if I can. But it seems only two kernels do well on my phone which is the netarchy toastmod, and king's #11 but neither will let me use it. Other kernels will let me use it but then the performance sucks. I like what I'm using because its quick and good on battery life, but I wish I could get that with my front camera working LOL. So ill make the sacrafice for now, but keep trying out new one's just incase I find one with everything I'm looking for.
I have a hardware version 0004 Evo running Myn's Warm 2.2 RLS5 and Netarchy Toastmod 4.3.4 cfs-havs-more-nosbc with latest radios and PRI v1.90_003. I'm also running SetCPU currently configured rather default at 998/245, smarta$$ scaling, and of course no profiles. I'm getting very reliable performance out of the combination. I wouldn't say my battery life is super unbeatably stellar, but it's much better than stock and easily lasts more than 24 hours of my typically moderate use.
I've been meaning to mess around a bit more with my SetCPU configuration, but haven't due to a combination of not enough time and not feeling the pressing need to tweak something that doesn't necessarily need it.
I keep playing around other ROMs (especially Gingerbread ones like CM7), but I always end up going back to Myn's. It just works for me.
I hope my grammer and punctuation meets everyone's approval -- I'm a bit nervous. :D
For some reason the 4.3.4 kernels run slow as hell, but the 4.1 kernels are fast as can be, LOL but I still can't get the front camera with a kernal that runs good. Its either front camera and the phone sucks or the phone is awesome and no front camera..... so I'm just gonna ditch the camera for now. Cause my shits super snappy.
try kings gb r2.. best of both worlds!!!!!!!!! with savage kernel
oh, and try tiamat for your kernel.... its stable as ____ and the link is in my sig.... i get phenominal batt life, and supreme performance
Winner! I can live with someone pointing out a few errors, but you can't be a hypocrite.
ugh.... I pointed out 1 error. 1! sheesh..... and i dont misspell things unless its obviously intentional, and meant to be lighthearted and comical. I only point out the kernel spelling because its so often misspelled.
So I bricked it flashing salvage mod....... what happened was I flashed the rom then lost root, but I didn't realize this, so I tried to recover to myn's because I didn't really like it much. And it would lock on the boot screen then bootloop on me. I'm curious about why this would have happened. Because I didn't have a backup of salvage mod just the Rom zip. And I could load that back up unrooted. So I work at a shop and I smashed the **** out of it and got a new one mailed to me put it back to myn's twopointtwo, I'm good on flashing roms for a while I can't afford to brick another phone. Even though it didn't technically get bricked loosing root is bricked to me.
not exactly sure what you did but flashing a rom should not have made you loose root. to loose root you need to have s-on and the only way that i know of is to flash the unrevoked forever s-on tool. you sure that you actually did loose root (s-on)? i have flashed many many many roms including salvage mod and never have i lost s-off. as long as you follow these steps to flashing you should be good to go:
1.make a nandroid backup
2.wipe everything
3.flash rom
the first two are key. nandroid backups are you friend. and there are several ways to wipe. you can wipe data, dalvik cache, and cache as well as system. also you can use caulkin's format all .zip here is the link: Calkulin's_FORMAT_ALL.zip. just flash this as you would a rom and it will wipe everything for you. i manually wipe then flash caulkins to make sure that i have a clean slate for any custom rom to work with.
LMAO a bit drastic but whatever works for you :). I guess, maybe..it was easier...? but it probably cost you some money. If it happens again you can always come here and we can help. There is only one issue i have ever seen that we cant fix, everything else for the most part is fixable.
Flashing a rom will not cause you to loose full root. Technically unrevoked 3 runs unrevoked FOREVER so you should maintain s-off. OCN is correct the only way I know to get it back on is to flash the s-on tool. Having said that I have seen people have s-on after they thought they had s-off. Not sure what they did...maybe there is some glitch where s goes back on or they just had no idea what they did and never had s-off or flashed the s-on tool. Either way we could always just root it again.
Point is you can safely flash roms without unrooting your phone. If s-off remains but you unroot your rom or lose recovery the fix is as simple as flashing a file, but neither of those things should technically happen either. Your phone was soft bricked at MOST, likely just boot looped. Point is you can smash your phone all you want but if you'd like an alternative, we can fix it :). Continue flashing to your hearts desire just follow the proper procedures and all should go well, if it doesnt we are here.
I did have s off but yeah he rom became unrooted. But the recovery that I had that I made just before my flash wouldn't boot back up. So i tried to run unrevoked on salvage mod which wouldn't work. So I just smashed it, yeah it costed me a hundred dollars, but the problem is I didn't learn a lesson from it because I'm not sure what went wrong here. Recovery wouldn't flash back, and 2.3 became unrooted? Wtf mate!!
BTW I don't have a computer, so everything I flash is done by downloading from my phone, moving files with astro, and just reading about recommendations and what to do, so once my phone bootstrapped on me after trying to reroot unrevoked on salvage mod. I had no way to read about what to do.
Oh and also I tried downloading myn's twopointtwo again and restarting and installation was aborted many times on me, I think my phone might have just defected on me or something crazy I'm not blaming any files or anything like that, I have done a lot of reading on this before and after the fact. But have no idea what happened. Ramon RA would not let me flash anything except an unrooted version of salvage mod
