Yes. Currently you're not in the directory. I advise you to put in on desktop. Then type "cd Desktop". Then "ls" to see if it's the righz one where the files are. With "pwd" you can checl where you currently are
i dont know what android was on it i bought it like that.Now hold volume up and connect to pc. But first try to power on normally(depending what android you had on it)
no!!!!Yes. First disconnect from pc. Then connect battery, hold volume up and connect to pc. Download mode should be working now
in windows i get failed (remote:flash write failure)No download mode?
Ok now flash the other files also
fastboot flash tz tz.img
fastboot flash rpm rpm.img
And other files(you can do it feom windows)
i bougt it from someone in that status.Appears to me you have a d802, not a d800. Are you working off the premise you have a d800? Have you verified motherboard?
than what do i need to do to make it come aliveIf you bricked it by flashing anything d802 related then it's obviously d800.
i flash all 7 filesYeah the touch problems are indicating likely not d802 but you are making assumptions nonetheless. Motherboard is best verified as they are not always d800, but they are the most likely candidate by far, probably near 90%.
So you need to write aboot, boot, dbi, laf, rpm, sbl1 and tz as mentioned.
yes im doing this from noppixStill fastboot? Can you flash again?
Dd if=/dev/null in front of "of=..." or "dd if=/dev/zero"
Hey wait..check with gdisk -l /dev/sdd if something changed
