Root need halp with dd comands after copy files to lg g2
aboot is the one that's most troubling as it should be sized identically on both KK and LP. There should be no space error there.
kitkat: aboot = 1024kb, boot = 10.5 mb, laf = 15.5 mb, sbl1 = 512 kb
lollipop: aboot = 1024kb, boot = 16 mb, laf = 32 mb, sbl1 = 1024 kb
So regardless of which partitions were used here, aboot should not receive the no space error as you're writing a 1024 kb partition to a 1024 kb space. Currently, the partitions are showing sizes indicative of lollipop, but I'm beginning to believe LP partitions were flashed to a GPT designated for KK partition table/sizing.
what the last part that u saying i couldent understand sorry
^ please look up the post again
i just read #3
i need to do that from win? icant understand what ? mean
D800
dd if=modem.img of=\\?\Device\Harddisk1\Partition1
dd if=sbl1.img of=\\?\Device\Harddisk1\Partition2
dd if=dbi.img of=\\?\Device\Harddisk1\Partition3
dd if=aboot.img of=\\?\Device\Harddisk1\Partition5
dd if=rpm.img of=\\?\Device\Harddisk1\Partition6
dd if=boot.img of=\\?\Device\Harddisk1\Partition7
dd if=tz.img of=\\?\Device\Harddisk1\Partition8
dd if=misc.img of=\\?\Device\Harddisk1\Partition13
dd if=recovery.img of=\\?\Device\Harddisk1\Partition15
dd if=laf.img of=\\?\Device\Harddisk1\Partition23
3. Bump boot for D80230b
so if i get it writh my file sytem partition is lollipop?
proprtis size
23 589824 655359 32.0 MiB FFFF laf 15.5 MiB (16,252,928 bytes)
2 163840 165887 1024.0 KiB FFFF sbl1 512.0 KiB (524,288 bytes)
5 229376 231423 1024.0 KiB FFFF aboot 1.0 MiB (1,048,576 bytes)
7 262144 294911 16.0 MiB FFFF boot 10.5 MiB (11,010,048 bytes)
so how can i flash the lol partitions?
or how can i resize partition that r to small
i dont care if my device will be 10G that works insted of 32 that brickd
proprtis size
The 30f partitions are lollipop:
http://downloads.codefi.re/autoprime/LG/LG_G2/D800/Stock_Firmware
It was my understanding that you have already tried the 30f partitions and you were not getting download mode but instead being constantly rerouted to fastboot mode, is that correct? Have you already tried the 30f partitions or no?
Because your quote above represents a kk partition table. But just several posts ago, you posted a table that represented LP:
Number Start (sector) End (sector) Size Code Name
1 32768 163839 64.0 MiB 0700 modem
3 165888 166911 512.0 KiB FFFF dbi
4 196608 197631 512.0 KiB FFFF DDR
6 231424 233471 1024.0 KiB FFFF rpm
8 294912 296959 1024.0 KiB FFFF tz
9 296960 296961 1024 bytes 0700 pad
10 327680 333823 3.0 MiB FFFF modemst1
11 333824 339967 3.0 MiB FFFF modemst2
12 339968 339969 1024 bytes FFFF pad1
13 360448 393215 16.0 MiB FFFF misc
14 393216 458751 32.0 MiB 0700 persist
15 458752 491519 16.0 MiB FFFF recovery
16 491520 497663 3.0 MiB FFFF fsg
17 524288 525311 512.0 KiB FFFF fsc
18 525312 526335 512.0 KiB FFFF ssd
19 526336 526337 1024 bytes FFFF pad2
20 526338 527361 512.0 KiB FFFF encrypt
21 557056 573439 8.0 MiB 0700 drm
22 573440 589823 8.0 MiB 0700 sns
24 655360 720895 32.0 MiB FFFF fota
25 720896 786431 32.0 MiB 0700 mpt
26 786432 787455 512.0 KiB FFFF dbibak
27 787456 789503 1024.0 KiB FFFF rpmbak
28 789504 791551 1024.0 KiB FFFF tzbak
29 791552 791567 8.0 KiB FFFF rct
30 819200 6488063 2.7 GiB 0700 system
31 6488064 7733247 608.0 MiB 0700 cache
32 7733248 7897087 80.0 MiB 0700 tombstones
33 7897088 7929855 16.0 MiB 0700 spare
34 7929856 8028159 48.0 MiB 0700 cust
35 8028160 30703615 10.8 GiB 0700 userdata
36 30703616 30777310 36.0 MiB 0700 grow
So I am confused on what is going on here.
i try the 30f partition. and nothing work .
but when i try the http://forum.xda-developers.com/lg-g2/development/tools-srk-tool-useful-toos-lg-root-twrp-t3079076
i dont know wich file he has .
but the ?? is what can i do to fix it thers no any way of formating all the 32G to one drive and than split it from the begining?
If you forced bulk once again, since your last effort, and now you are showing a KK partition sizes:
...then it would make some sense to me as the primaryGPT intructions may be rewriting itself back to kk sizes if it were in fact kk to begin with. If that is the case, then you should retry flashing the 7 partitions from the 10o firmware version and they should apply without the space error. This would be the case if you are CURRENTLY showing those partition sizes above.
i dont have any problem to force bulk again and start from the 1 step all over.
what about 10d partition?
This time, when you force bulk, give us the output of the partitions before doing anything else. We need to verify each partition size to see how they have been allocated.
somthing strang dont u think?????
root@Microknoppix:/home/knoppix/Downloads# gdisk -l /dev/sdd
GPT fdisk (gdisk) version 0.8.5
Caution: invalid main GPT header, but valid backup; regenerating main header
from backup!
Caution! After loading partitions, the CRC doesn't check out!
Warning! Main partition table CRC mismatch! Loaded backup partition table
instead of main partition table!
Warning! One or more CRCs don't match. You should repair the disk!
Partition table scan:
MBR: protective
BSD: not present
APM: not present
GPT: damaged
Caution: Found protective or hybrid MBR and corrupt GPT. Using GPT, but disk
verification and recovery are STRONGLY recommended.
Disk /dev/sdd: 61071360 sectors, 29.1 GiB
Logical sector size: 512 bytes
Disk identifier (GUID): 98101B32-BBE2-4BF2-A06E-2BB33D000C20
Partition table holds up to 36 entries
First usable sector is 11, last usable sector is 61071349
Partitions will be aligned on 2-sector boundaries
Total free space is 30552054 sectors (14.6 GiB)
from backup!
MBR: protective
BSD: not present
APM: not present
GPT: damaged
So yeah they're sized for Lollipop. I suppose try the 30f partitions but it seems like you've already tried that without success. Either that or attempt to zero the 7 partitions and write the 10o partitions instead. I'm not confident that would change the allocated size though so it may or may not work.
thank u .
i was trying to flash the 30f partition and its saying the same error. no more space left.
btw: did u see the list of partition i sent u image?
sdd,sdf what hapaned?
ivr asked couple of timeand now one gave anser.
1.is there a way to delete all partition and resize them?
2.is there a way of instaling some other rom (i dont care wich) to get back the phone to work?
what r my options? sell it for parts ?
thank u .
Try flashing always one set of partitions(first 10, then 20, then 30, until you get the download mode working)
i managed to flash all 30f partition but still im only entering fastboot and not download mode.
what about recovery? i dont need to flash as wale?
what can i do? please halp me......
ok so i was trying to flash the 10o files and i managed to get the first pic that is retten downloadmode and insted of going to download mode its jump to fast mode.
What does the etiquette on the mainboard say?
d800 and also the gold reben and neer the charging port.
ihave anouther q?
icen if its reteen d800 all over and thay sell it with back cover of d802.
shuld i try to flash d802 files?
if yes which model?
i have 32 g and on the box of the phone i have d802 imei as well.
