You don't need to reformat partitions. You do need to be careful as you type though. There's a reason dd is nicknamed "data destroy". Please be mindful of each character you type...post #51 in this thread has an error which is being noted by previous posters.
what do i miss???? it stell written no space laft on device in aboot/boot/sbl1/laf
root@Microknoppix:/home/knoppix/Downloads# dd if=aboot.img of=/dev/sdd5
dd: writing to `/dev/sdd5': No space left on device
1025+0 records in
1024+0 records out
524288 bytes (524 kB) copied, 0.0068872 s, 76.1 MB/s
root@Microknoppix:/home/knoppix/Downloads# dd if=dbi.img of=/dev/sdd15
1024+0 records in
1024+0 records out
524288 bytes (524 kB) copied, 0.00624214 s, 84.0 MB/s
root@Microknoppix:/home/knoppix/Downloads# dd if=boot.img of=/dev/sdd7
dd: writing to `/dev/sdd7': No space left on device
6145+0 records in
6144+0 records out
3145728 bytes (3.1 MB) copied, 0.0332832 s, 94.5 MB/s
root@Microknoppix:/home/knoppix/Downloads# dd if=sbl1.img of=/dev/sdd2
dd: writing to `/dev/sdd2': No space left on device
1+0 records in
0+0 records out
0 bytes (0 B) copied, 0.000472261 s, 0.0 kB/s
root@Microknoppix:/home/knoppix/Downloads# dd if=rpm.img of=/dev/sdd6
1024+0 records in
1024+0 records out
524288 bytes (524 kB) copied, 0.00496202 s, 106 MB/s
root@Microknoppix:/home/knoppix/Downloads# gdisk -l /dev/sdd
GPT fdisk (gdisk) version 0.8.5
Caution: invalid main GPT header, but valid backup; regenerating main header
from backup!
Caution! After loading partitions, the CRC doesn't check out!
Warning! Main partition table CRC mismatch! Loaded backup partition table
instead of main partition table!
Warning! One or more CRCs don't match. You should repair the disk!
Partition table scan:
MBR: protective
BSD: not present
APM: not present
GPT: damaged
Caution: Found protective or hybrid MBR and corrupt GPT. Using GPT, but disk
verification and recovery are STRONGLY recommended.
Disk /dev/sdd: 61071360 sectors, 29.1 GiB
Logical sector size: 512 bytes
Disk identifier (GUID): 98101B32-BBE2-4BF2-A06E-2BB33D000C20
Partition table holds up to 36 entries
First usable sector is 11, last usable sector is 61071349
Partitions will be aligned on 2-sector boundaries
Total free space is 30552054 sectors (14.6 GiB)
Number Start (sector) End (sector) Size Code Name
1 32768 163839 64.0 MiB 0700 modem
2 163840 165887 1024.0 KiB FFFF sbl1
3 165888 166911 512.0 KiB FFFF dbi
4 196608 197631 512.0 KiB FFFF DDR
5 229376 231423 1024.0 KiB FFFF aboot
6 231424 233471 1024.0 KiB FFFF rpm
7 262144 294911 16.0 MiB FFFF boot
8 294912 296959 1024.0 KiB FFFF tz
9 296960 296961 1024 bytes 0700 pad
10 327680 333823 3.0 MiB FFFF modemst1
11 333824 339967 3.0 MiB FFFF modemst2
12 339968 339969 1024 bytes FFFF pad1
13 360448 393215 16.0 MiB FFFF misc
14 393216 458751 32.0 MiB 0700 persist
15 458752 491519 16.0 MiB FFFF recovery
16 491520 497663 3.0 MiB FFFF fsg
17 524288 525311 512.0 KiB FFFF fsc
18 525312 526335 512.0 KiB FFFF ssd
19 526336 526337 1024 bytes FFFF pad2
20 526338 527361 512.0 KiB FFFF encrypt
21 557056 573439 8.0 MiB 0700 drm
22 573440 589823 8.0 MiB 0700 sns
23 589824 655359 32.0 MiB FFFF laf
24 655360 720895 32.0 MiB FFFF fota
25 720896 786431 32.0 MiB 0700 mpt
26 786432 787455 512.0 KiB FFFF dbibak
27 787456 789503 1024.0 KiB FFFF rpmbak
28 789504 791551 1024.0 KiB FFFF tzbak
29 791552 791567 8.0 KiB FFFF rct
30 819200 6488063 2.7 GiB 0700 system
31 6488064 7733247 608.0 MiB 0700 cache
32 7733248 7897087 80.0 MiB 0700 tombstones
33 7897088 7929855 16.0 MiB 0700 spare
34 7929856 8028159 48.0 MiB 0700 cust
35 8028160 30703615 10.8 GiB 0700 userdata
36 30703616 30777310 36.0 MiB 0700 grow
root@Microknoppix:/home/knoppix/Downloads# dd if=laf.img of=/dev/sdd23
dd: writing to `/dev/sdd23': No space left on device
1+0 records in
0+0 records out
0 bytes (0 B) copied, 0.00016824 s, 0.0 kB/s
root@Microknoppix:/home/knoppix/Downloads# dd if=tz.img of=/dev/sdd8
1024+0 records in
1024+0 records out
524288 bytes (524 kB) copied, 0.138197 s, 3.8 MB/s
root@Microknoppix:/home/knoppix/Downloads# ^C
1024+0 records in
1024+0 records out
524288 bytes (524 kB) copied, 0.144175 s, 3.6 MB/s
1+0 records in
0+0 records out
0 bytes (0 B) copied, 0.000157593 s, 0.0 kB/s
