bender_007
Ok actually o got files prepared: https://www.dropbox.com/s/8vpg30q0hnvq74p/d802_32.zip?dl=0 extract and run the bat file..
i cant do it from my win com.Ok actually o got files prepared: https://www.dropbox.com/s/8vpg30q0hnvq74p/d802_32.zip?dl=0 extract and run the bat file..
ok now m in 9006 whith all disks .This is for fastboot to be ran out from windows. Or just ise the img/bin files provided inside the zip(32 gb version)
i flashd all files,Flash all
im getting serial port open fail. im on port 41.Not sure any more. Try the boarddiag 2.99 lr 3.99c tool.
if i insert imei into lg fw updte chack i getNot sure any more. Try the boarddiag 2.99 lr 3.99c tool.
ive chacked it its ritten d800.Its possible your eMMc is damaged. That should have worked. The other thing you could do is tear down the phone slightly farther and look on the underside of the motherboard to once and for all rule out a different model. I've seen a few d800 markings including ribbon cables that ended up having a d801 mobo. Rare but seen it a time or two.
i dont want to flash it on lineIt may be correct or not correct. You can download, extract and try to flash the partitions
