Can you guys help me root my lg ally it would be much appreciated![]()
To use this you have to go to applications>enable unknown sources, and after you download it download astro file manager (on the market) and use that to install it
Or, just enable USB Debugging and install it with "adb install".
Some new comers may not know what adb is or the android sdk for that matter.![]()
i agreeIf they're venturing into the world of root, they should learn![]()
