I rooted my phone about a year ago and all i use it for is to theather on internet. do i need to root it with new software?
and how do you flash vzw prl? something to do with roaming isnt it?ive always been too paranoid to update my radios (other than flashing the vzw prl, that is) cuz of all the perma brick stuff ive read![]()
but can go back to an aosp once the prl is changed and itll stick on the vzw prl
What are the advantages?nope. you need to get your msl (easiest way is with the msl reader apk) and then download the vzw prl .zip file and put it on your sd card. You then type ##prl# on the dialpad and itll ask you for the msl. Make sure you type it correctly as it only gives you 3 chances before permanently disabling your phone entirely, then the phone will launch an installer thatll ask you which file you want to install. Find the prl.zip file (the one i use is 00001.zip) and install it. The phone will then reboot and viola. You now have a verizon Evo LoL you can verify that it worked by dialing *2. If it worked, itll say "thank you for calling verizon activation....."Sidenote, you must be on a sense based rom for this to workbut can go back to an aosp once the prl is changed and itll stick on the vzw prl
Radio flashing is only dangerous with a bad download or shutting your phone off or having the battery die while updating. I trust amon ra 2.3 completely and to do it right.
yeah, i guess im just too skittish to try it. Murphy and hhis dumb frickin law just seem to intervene in my life too often to trust that he wouldnt get involved there lolWhat are the advantages?
What if I need to go back to Sprint? Is there something about doing this on this forum or XDA? Thanks for any info YD! My son's Sprint signal is non existent where he is, but his GF is on Verizon and she is fine...
Thats the advantage LoL and yeah, if you want to go back to sprint coverage, yo just need to update the prl via the settings menu when using a sense based rom. I get WWWWWWWAAAAAAAAAAYYYYYYYYYYYYYY better service on the vzw prl vs the sprint one cuz sprint service kinda sucks where im at too....
Fair enough, and if your signal is fine, then I guess there's no point in updating. It is truly the one thing you need to be careful about when flashing because you can brick your phone if you pull the battery or let the battery die while flashing.amon is amazing!yeah, i guess im just too skittish to try it. Murphy and hhis dumb frickin law just seem to intervene in my life too often to trust that he wouldnt get involved there lol
I found this link over at XDA...
Files of oostah
How the hell do you know which one to use? I saw you were on 00001.zip, and by doing this it means you are roaming all the time, right? Where does Sprint draw the line on that?
On the advice of another forum member, I called Sprint and explained my situation... They are sending me an airwave, which is a mini tower that links up with regular towers and runs off high speed internet. It's free, give them a call. I would try this befor eupdating my prl.
